Got tossed the keys to this bike a little over a week ago and its going from almost full dress to naked by the time its done
Intended Mod list:
Strip all fairings and install round headlight
One up seat w/ custom rear fairing
aluminum trim panels over the battery / ecu area
Modified handle bars more in line w/ the euro bars
Lowered 3/4" (more if i can manage)
relocated ignition switch (airbox ?)
Custom saddle bag mounts for when i actually have to haul something
Maybe custom rear sets and a muffler swap
Required repairs:
gauge cluster lens replacement
misc engine seals (mostly oil pan)
rebuild or replace front forks
new rear shock
full prevent. maint. chassis & drive line lube
replace clutch cable
oil throttle cable
repair / replace gear indicator switch.
Final color: maybe the original grape, maybe titanium, no idea yet.
10 min after it arrived @ the shop
(https://scontent-b-lga.xx.fbcdn.net/hphotos-frc3/292930_10151236535922425_1763909805_n.jpg)
the next day (only spent a little while messing w/ it)
(http://scontent-b-lga.xx.fbcdn.net/hphotos-frc3/255541_10151238282392425_1210407112_n.jpg)
and heres some of my inspiration:
(http://2.bp.blogspot.com/-IUdvHhW-XB8/TxCdOZG2eNI/AAAAAAAAArg/JBP9LllGbaI/s1600/YohannORYCafeRacer2.jpg)
(http://img130.imageshack.us/img130/1663/5064857g.jpg)
(http://media-cache-lt0.pinterest.com/upload/228909593530079755_lmJuCIDe_c.jpg)
Yea, the B&W picture the tail is like a wasps ass up in the air, the back and gold checkered bike owner was to pussy to cut his frame, but the orange bike the tail works w/ the tank recesses
Ive got an idea for the tail, just have to make some JY runs till i find the panels I need. should flow well w/ the tank design.
Apparently the front forks are a known problem and using parts off the later R series is an upgrade. (I'm working off my shit memory at this point so dont quote me) But I'm def not afraid to rebuild some bike struts.
had a few spare minutes today, pulled off the remainder of the fairings. Horns are still on the HL bracket (need to disassemble some wiring to get the bracket off)
(https://scontent-b-lga.xx.fbcdn.net/hphotos-frc3/t1/523064_10151244753882425_1347924308_n.jpg)
No Disassemble ... wait ... nevermind.
Started digging into the bike deeper last week. Should have a headlight coming at some point. Been calling around trying to find the pieces i need for the rear fairing. Have to fix a coolant leak, a bad cooling fan, and possibly some bad intake boots.
Need to make some pieces so i can lower the gauge cluster way down also
(http://sphotos-b.xx.fbcdn.net/hphotos-snc6/281168_10151254827372425_1775774105_o.jpg)
ignition has a mile of extra wire, so Im moving it to the side of the bike w/ a custom bracket
(https://scontent-a-lga.xx.fbcdn.net/hphotos-ash2/184111_10151254831892425_669659181_n.jpg)
sleeping w/ the enemies
(https://scontent-a-lga.xx.fbcdn.net/hphotos-ash2/523076_10151250909137425_1480553339_n.jpg)
so i had the tank off for like a week. both for the sake of pulling the front light wiring and running the clutch cable. you wouldnt beleive how many people thought i had ruined the bike or that id never get it back together.
so today i put the clutch cable in it and put the tank back on. made it do this again:
(https://scontent-a-lga.xx.fbcdn.net/hphotos-frc1/303179_10151260022067425_360756686_n.jpg)
My 1985 naked / cake brick build thread
Who did the paint and what color orange did you use?
Atomic orange, a fitting name for paint on a brick. Ford has a paint called "screaming yellow" that I have considered for my bike.
A close friend paints cars for a living and he told me that he would paint my last bike just for the cost of the paint. About 65 bucks.
The other day, one of his coworkers ran up behind him and jumped on Jim's back, crushing some of his disc. Looks like Jim will never work as a painter again. To the best of my knowledge, his coworker still has a job. If I was his employer, I would be considering giving him the boot.
(http://img.photobucket.com/albums/v473/hotrodkid/imagejpeg_31_zpsd8e2f1a3.jpg)
getting rid of the forging line on the wheels.
Primed fork legs
(https://fbcdn-sphotos-a-a.akamaihd.net/hphotos-ak-ash4/462680_10151694147112425_1694043008_o.jpg)
Painted block
(https://fbcdn-sphotos-a-a.akamaihd.net/hphotos-ak-ash3/922660_10151694147357425_1416029627_o.jpg)
pulled teh frame off, painted it and the folk legs
(https://fbcdn-sphotos-h-a.akamaihd.net/hphotos-ak-ash4/478742_10151694147417425_660118932_o.jpg)
Painted the trans case
(https://fbcdn-sphotos-d-a.akamaihd.net/hphotos-ak-ash4/919428_10151694147542425_45061008_o.jpg)
went to cut some wood and the table saw tried to kill me... you must be related to my shop partner.
