TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: captrusty on September 23, 2012, 04:38:28 PM
Title: Got My K1100lt back today
Post by: captrusty on September 23, 2012, 04:38:28 PM
Hi guys, I sold my lt a few months ago took most of the cash up front and held the note on the rest for what I thought was a good guy.....anyway got her back today plus two boxes, looks like during a barback install the lt dash didnt quite work so dash wires are all cut front brake line to from the brake lever cut and partly missing, so far thats what I have noticed. ok so heres my questions : can the switches be moved up to the dash where the blanks are ? will they just snap in ? and can I just splice wire between the switches and run them up to the new position? the flasher switch is missing so can I just tape the wires off and run with out it with no problems? I have already read the brake bleeding info so that shouldnt be a problem ( i hope) anyway thanks for any input And I am glad to have her back I really wanta get her going for some fall New England riding
Title: Re: Got My K1100lt back today
Post by: frankenduck on September 23, 2012, 04:59:20 PM
Same switches above and below so yes, they'll pop right into the upper holes.
All the flasher switch does is send a ground to the flasher relay.  You might want to consider pulling the tank back and disconnecting the connector if you'e not going to replace the switch.
Post by: captrusty on September 23, 2012, 07:57:43 PM
Thanks Duck, I'll be doing that tomorrow.
