TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: k75bobber on September 21, 2012, 08:45:34 PM
Title: REPLACE GAUGES WITH SINGLE SPEEDO
Post by: k75bobber on September 21, 2012, 08:45:34 PM
Hi everyone. I recently bought a k75 as a project for the winter.
Im wanting to change to a single small speedo as i am going for a minimal bobber look
Has anyone on here done this ? would any digital speedo work?
many thanks
Andy
Title: Re: REPLACE GAUGES WITH SINGLE SPEEDO
Post by: wmax351 on September 22, 2012, 12:05:54 AM
Its doable. There should be a writeup on here somewhere. You will have to use one with a Variable Reluctance sensor conditioner or setup a separate sensor for the wheel speed.
Rpm wise, it should be easy to catch the tach pulse from the ignition controller.
You will also need to emulate the "start in neutral" setting with some relays.
