TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: tsbt on September 21, 2012, 04:52:51 PM
Title: That time of year again for chilly fingers or heated grips
Post by: tsbt on September 21, 2012, 04:52:51 PM
Looking at Symtec with Heat-troller, does the alternator on the K100RS support it? or should I upgrade my alt to a 50? I suppose if I want CATZ and a Xenon bulb I should upgrade the alt anyway. Did I just answer my own question...:hmm:
Title: Re: That time of year again for chilly fingers or heated grips
Post by: frankenduck on September 21, 2012, 05:05:29 PM
$4 - variable heated grips mounted in dash pad:
(http://i1221.photobucket.com/albums/dd470/Motobrick/heated_grips/vhg2c.jpg)
Variable heated grips - Version 2.0 (http://www.motobrick.com/index.php?topic=1243.0)
Post by: leecow on September 22, 2012, 04:23:28 PM
Ah inflation ... price is up to $7.99.
http://www.ebay.com/itm/PWM-Dimming-Controller-For-LED-Lights-or-Ribbon-3528-5050-strip-12V-8A-Dimmer-/190722817388?pt=LH_DefaultDomain_0&hash=item2c67f73d6c (http://www.ebay.com/itm/PWM-Dimming-Controller-For-LED-Lights-or-Ribbon-3528-5050-strip-12V-8A-Dimmer-/190722817388?pt=LH_DefaultDomain_0&hash=item2c67f73d6c)
Post by: Motorandy123 on September 23, 2012, 08:17:36 AM
I found an ad that says they draw 3 amps on high (heated grips). That's only 36 watts so should be OK by themselves.
When you add the other stuff you might be pushing it (literally!).
If you throw a 50 watt HID in the headlight you wouldn't need the 50 amper...
Post by: frankenduck on September 23, 2012, 10:42:24 AM
The CATZ XLOs are 70W each.
