TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: moynistan on September 21, 2012, 04:52:50 PM
Title: Coolant temp sensor junkshow...
Post by: moynistan on September 21, 2012, 04:52:50 PM
OK, I replaced my coolant temp sensor today, and when I pulled it, I saw this:
(http://i1140.photobucket.com/albums/n572/moyniman/file_zps1e76141d.jpg)
Pulled it out with a pick and it looks like this:
(http://i1140.photobucket.com/albums/n572/moyniman/file_zps6580a070.jpg)
Looks like a rubber band accidentally dropped into the system(?!), but if anyone knows better please sound off.  I haven't had any coolant leaks in the system that I know of...  Guess i should be glad it ended up someplace that I could remove it so easily?
Cheers,
KM
Title: Re: Coolant temp sensor junkshow...
Post by: frankenduck on September 21, 2012, 05:06:58 PM
Its probably sealant from the water pump cover.
Post by: moynistan on September 21, 2012, 05:36:43 PM
Yup, when I cleaned up the timing chain cover, I found the extruded sealant to be the same stuff.  good to get it out at any rate.
