TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Gubro30 on September 17, 2012, 11:58:20 AM
I'm ordering SS lines from these guys as the previous ones didn't offer threaded fittings.
Which ones do I need for the lines that go from the Y junction under the steer tube to the brake calipers steel rigid lines?
Thanks!!!
R, it`s pictures of the fittings on the end on the brake line at MaxBmw. (http://www.maxbmwmotorcycles.com/fiche/DiagramsMain.aspx?vid=51741&rnd=08102012)
Inge K.
Inge K.
Thanks Inge - R seems to be the correct fitting for the junction to the caliper.
And regarding the top fitting that connects to the Y, should I get S or T ?
Isn`t it a banjo fitting at the top of the Y?? If plan to change the line between the MC and Y, G seems to be the closest match on the Y end of that line.
Inge K.
On top yes.
I compared Maxbmw pictures of both end of the #07 line and got my answer. It's for under the steer tube, and to the metal line on the calipers that I was unsure. One is Male the other Female.
Thanks!
Guillaume
Sorry, did misunderstand the question in the first post.....I thought did have the spesific fittings in the bottom of the Y in mind, only.
R would be correct at the Y end, but I`m not shure if it`s S or T at the bottom (calipper) end.
Inge K.
