TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: moynistan on September 16, 2012, 08:31:03 PM
I disassmbled the switchgear per Lieberry instruction. Everything is clean, and wiring/soldering looks great. I can see what is happening when I move the switch and cannot understand why the Hi beam won't flash... :dunno2:
Any takers?
Do you got power on the green/blue wire? If not, check the connector under the tank.
Inge K.
Thanks, obviously I'm pretty limited in my understanding of electrical matters, I appreciate your patience with a noob.
SOLVED: missing micro screw on hi low beam switch replaced and cleaned contacts, reconnected and good to go.
