TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: 1986 k75s on September 16, 2012, 09:20:05 AM
Title: Went on holiday for three weeks and she wont start battery now flat from trying?
Post by: 1986 k75s on September 16, 2012, 09:20:05 AM
Got back from hols wheeled the k75s out of the shed hit the starter button she started up then died . Probably a bit cold me thinks ,tried again huge backfire cloud of greyblue smoke then wouldnt start . Battery now gone flat so removed to charge on motorcycle charger. The plugs were soaked in fuel dried them and cleaned them but still didnt want to start . I notice the buzzing from the fuel pump had stopped the last few tries b4 i removed the battery , just the small backfire .
Was wondering if the fuel pump stops working when the battery gets really low on power ? Fuse hasnt blown that being fuse number 6 in fact no fuses have blown
Bike is a 1986 S model k75 an old dog in reality but with low mileage of 32000 for a 26 year old bike .
Advice please ?  :dunno
Title: Re: Went on holiday for three weeks and she wont start battery now flat from trying?
Post by: Inge K. on September 16, 2012, 02:58:54 PM
Since your fuel pump don`t turn anymore, measure if you got voltage at fuse #6 while pushing the starter button.
If you got power, the problem is the fuel pump, tank connector or related wiring.
If you ain`t got power, the problem is the FI relay or related wiring.
Inge K.
Post by: 1986 k75s on September 17, 2012, 07:46:43 AM
Cheers friend i will try that can you explain the trick of reversing the pump to possibly unblock it  ?
Post by: Inge K. on September 17, 2012, 09:17:06 AM
Reverse the polarity at the pump.
Inge K.
Post by: 1986 k75s on September 17, 2012, 02:41:10 PM
After a good charge on the battery i returned to the bike . I have learned a valuable lesson at this point BMWs are very fussy things for eg dont put the battery back in b4 you put the water filler in eg . A press of the starter and brooooommmm she starts up like nothing was wrong the fuel pump buzzing happily aswell .
So it would appear that a low battery is the cause of my problems and that is all .  :neener:
