TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Gubro30 on August 25, 2012, 11:27:26 AM
Title: Open-ended heated grips? Also is it possible to use after-market bars with heated grips?
Post by: Gubro30 on August 25, 2012, 11:27:26 AM
I have the original, closed rubber end BMW heated grips. I want to install bar-end mirrors to replace the mickey-mouse ears original ones.
How can I do this? Did BMW make open ended heated grips? Can the end of the grips be cut or is it where the wires attach?
Lastly, can I use aftermarket bars with the oem heatedgrip setup?
Thanks!
Title: Re: Open-ended heated grips? Also is it possible to use after-market bars with heated grips?
Post by: frankenduck on August 25, 2012, 11:43:58 AM
BMW added bar ends wiith heated grips by cutting a notch in the end of the handlebar and having a hollow mount for the bar ends that the HG wiring could pass through.
(http://www.kbikeparts.com/p/120319/hgcbars.jpg)
If you want to install bar end mirrors:
a) Maybe you could run the wires under the grip rubber.  :dunno Make sure the throttle side wires don't chafe when you twist the throttle.
b) Aftermarket heated grips with an OEM switch (http://www.motobrick.com/index.php?topic=328.0)
Post by: Gubro30 on August 25, 2012, 12:02:23 PM
Thanks Duck! I guess drilling a tiny hole in a low-stress area of an aftermarket steel bar would be a no-no?
Post by: Gubro30 on August 25, 2012, 12:14:39 PM
Or I could simply modify the bar end mirrors fitting and file a notch at the end of whatever bars I use?
Post by: frankenduck on August 25, 2012, 12:17:30 PM
Why?  It's not like handlebars are subjected to a lot of force/stress.  Drilling and tapping a couple of holes for the left heated grip shouldn't matter.
Post by: Gubro30 on August 25, 2012, 12:34:29 PM
True.
I'm back from a 3days 1000miles ride with a friend who's on a 2010 Duc Monster 796, and now I'm definitely longing for a handlebar setup like his (lower, a bit straighter and wider. I'm 6'5" and am always on the very end of the bars)
Post by: frankenduck on August 25, 2012, 01:06:15 PM
Try some K75S/K100RS bars..... :mbird
Post by: Gubro30 on August 25, 2012, 01:46:01 PM
I'm looking at something like this dimensions-wise (without the lame cross-brace)
http://www.bikebandit.com/renthal-7-8-road-bars?m=87 (http://www.bikebandit.com/renthal-7-8-road-bars?m=87)
Post by: frankenduck on August 25, 2012, 02:07:28 PM
The tolerances on pretty slim inside the clutch and throttle perches.  7/8 is bigger than 22mm.
Flanders makes some 22mm bars though.
Post by: Gubro30 on August 25, 2012, 02:24:04 PM
7/8 is 22.225mm, you think that would be too tight?
Post by: frankenduck on August 25, 2012, 02:36:11 PM
Got me.  All I know is that those perches are pretty snug on 22mm BMW handlebars.
Post by: Gubro30 on August 25, 2012, 02:45:41 PM
I'll let you know :)
