TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: rbm on August 19, 2012, 10:26:56 PM
I'm swapping rear shocks between my bikes -- a 88 K100RT and 87 K75C. Went to fit the RAM rear shock to the K75C and discovered that the frame receptical is an eyelet pipe and not a pair of plates, as on the K100 frame. The old shock has a fork upper mount and an eyelet lower mount.
The existing shock has mounts along these lines:
(http://www.jcmotors.com/images/PRODUCT/medium/JCM-465-1101.jpg)
The RAM shock looks like this:
(http://www.realmengineering.com/_wp_generated/wp66e4ef75.png)
What are my options here for installing the RAM shock? Will this require cutting out the existing eyelet pipe and welding on a pair of steel plates in place of the eyelet pipe? It may or may not be important to know that I'm planning for an upgrade to a Paralever rear drive in the future, as that decision will require a 4V shock installation.
A RAM shock should bolt right up to any stock K frame.
Post up a picture of what the upper frame mount looks like on the bike that that first shock came from.
i have never seen a K with that mounting at the top.
Modded by PO, I`ll guess.
Inge K.
Ok, here are pictures of the shock mount. What I'm expecting to see:
(https://lh4.googleusercontent.com/-al27EDE9_ng/UDK2tYYU09I/AAAAAAAAB1Q/g2r-5n9rWg8/s400/IMG_1144.jpg)
What is actually on my frame:
(https://lh3.googleusercontent.com/-KKv-ClX5KXw/UDK2vwDZPDI/AAAAAAAAB1Q/BCAyTDDRFZ8/s400/IMG_1146.jpg)
It does appear to be a mod by the PO; the work was high quality and it took me feeling for the grinding marks to discern the deception. Obviously it was done to accomodate a shock that happened to be available rather than get the real shock. :nono
It means I will have to get a mechanic's shop to revert it back to the standard mount by welding on mounting plates. :dunno
What I would guess have happened is that a PO have been driving around with a loose upper bolt for a longer time, and the holes have been elongated/out of shape.
Seems like you have some work ahead.
BTW. Your seat hinges needs to be lubricated, and you missing a clips.
That front E-clip isn't really necessary. (Unless you're using it to carry a spare. :yes)
Yes, I know. That E-clip was on the bike yesterday because I put it there. It wasn't there today because it fell off. I did find it (miracously) on the garage floor this evening after taking the pictures and noticing the same thing myself. You'd realize it is a miracle if you ever saw my garage floor. :eek:
