TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: k100 on August 17, 2012, 05:29:34 PM
ok thanks for all the info on fitting up gages guys but as you may have guest by now it was'nt of much ues as my old girl is pree 85 and seams to be different from all other k bikes. so how to fit water temp gage ? and is it possibell to fit fuel gage to this model without changing fuel tank ?.
Temp gauge:
Install sensor to replace drain plug. Run wire from temp sensor to black wire for temp gauge.
Tap gray/blue wire into any other gray/blue wire under the tank.
Tap green/black wire into any other green/black wire under tank.
Ground the brown wire.
Fuel gauge: I think you're hosed there. If you switch tanks/fuel level senders then a post 85 tank won't mount up to an 85 frame.
ok so its a volt meter instead just to balance things lol . thanks for the info itll help
I have done it (84 bike), no worries. As above; fit the sensor in the drain plug hole of the cooling water pump and run a wire up. You can use the BMW wire/sensor set if you feel rich and run the wire under the tank. In the loom of the early K's there's a 3-lead plug for 'additional instruments' (yes, indeed!), where you can take your power/ground and light signal from. Run a piece of loom from there to the intended location for the gauges and you're done. I have fitted mine (Cooling water temp and Volt) in the left compartment of the fairing.
Cheers, Rene
cherrs were did you rout the wier from the temp sender ? and how i tryed to go in the same place as the other temp sender after feeding 2 meters of wier up that black hole an not finding it cuming out i gave up :dunno had the radiatour off and the air box out and still no sine of were it gos black hole is right lol
The wires is routed behind the water pump cover and the hall sensor cover.
Remove the hall sensor cover (T-shaped), run a stiff wire behind the w.p. cover
use this wire to drag the sensor wire through.
Inge K.
thank you verry much for the help :2thumbup:
