TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: TimTyler on August 12, 2012, 10:52:15 PM
Title: Where Does This Ground Wire Connect
Post by: TimTyler on August 12, 2012, 10:52:15 PM
Putting the bike back together. Almost complete after three loooong days of nitrile gloves.
This electrical connector comes down from under the tank towards the battery / starter area and is grounded even though the jacket is red.
Where might I connect it?
Title: Re: Where Does This Ground Wire Connect
Post by: Rick G on August 13, 2012, 12:56:06 AM
There is an earth connection on thr gearbox just above the coils.  Socket head screw 6mm thread and 5mm hex. There are usually more than one eth connected there.
Post by: TimTyler on August 13, 2012, 03:15:18 PM
Thanks, Rick!
I found this photo too (not my bike) that shows it connects to the same place as the battery ground.
Title: Re: Where Does This SPRING Go?
Post by: TimTyler on August 13, 2012, 04:25:54 PM
This small spring is the only part left over from my clutch rebuild. I thought it came off the side stand / center stand, but for the life of me I can't see where.
Post by: mystic red on August 13, 2012, 05:25:44 PM
When in doubt, check the fiche. #13?
(http://www.maxbmwmotorcycles.com/fiche/DiagramsMid/B0000997.png?v=08102012)
http://www.maxbmwmotorcycles.com/fiche/DiagramsMain.aspx?vid=51743&rnd=08102012 (http://www.maxbmwmotorcycles.com/fiche/DiagramsMain.aspx?vid=51743&rnd=08102012)
Post by: Motorandy123 on August 13, 2012, 06:45:07 PM
It looks like the rear brake pedal spring.
My bike has only one wire on that ground point, it is a smaller wire and goes
straight to the battery. Maybe 50 amp bikes have a bigger wire too?
Post by: TimTyler on August 13, 2012, 08:01:19 PM
Yeah - I did that.
I have two each of the #13's and the #7's and they're all considerably thicker and twice as long as this little leftover spring.
Post by: Uffda on August 13, 2012, 08:21:57 PM
I had the same problem 2 years ago after doing my first spline job.  Same little spring left over with no obvious place to go.  And I posted the same question you had...."Where does this left over spring go?"  As Randy said, it's the brake lever spring.  One end goes between the #7 springs on your center stand and the other end attaches to a spot near your MC.  Good luck.
#9 in attachment
Post by: TimTyler on August 13, 2012, 08:28:14 PM
Bingo! That was it. Thanks, guys.
Post by: Photog on August 14, 2012, 08:23:32 AM
Later K's (don't know what year, it's probably documented in here somewhere), have a bigger ground wire. Mine is an 87 and the factory wire is almost scary thin.
Euro Moto Electrics has a nice kit with upgraded battery wiring. You can roll your own too, of course. I found however, that the euromotoelectrics kit was very cost effective compared to a DIY effort.
