TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: k100 on August 11, 2012, 04:40:42 AM
Title: how do i fit a temp gauge to k100rs
Post by: k100 on August 11, 2012, 04:40:42 AM
what type of sender unit do i use our can it be uesd on the standead one aney info would be good....  :k100rs
Title: Re: how do i fit a temp gauge to k100rs
Post by: k100 on August 11, 2012, 07:24:27 AM
is there aneything speshall about the gaeg our will aney do
Post by: rbm on August 11, 2012, 02:51:41 PM
Which temperature are you trying to measure -- oil or water?
If oil, the sender replaces the oil drain plug.  Any sensor with M15 thread and can place 80ºC at midscale. The gauge should have a range 40ºC - 100ºC.   If water, the sensor connection is part of the wiring harness.
Post by: k100 on August 12, 2012, 02:06:06 AM
so i should be Abel to by a generic water temp gage and connect to eggsisting  wiring ?
Post by: rbm on August 12, 2012, 11:35:26 PM
http://k100rt.aforumfree.com/t1923-installing-additional-instruments-temperature-and-fuel-gauge-work-completed (http://k100rt.aforumfree.com/t1923-installing-additional-instruments-temperature-and-fuel-gauge-work-completed)
http://k100rt.aforumfree.com/t1311-installing-a-water-temperature-gauge (http://k100rt.aforumfree.com/t1311-installing-a-water-temperature-gauge)
Post by: k100 on August 13, 2012, 12:47:05 AM
 :2thumbup: thank you
Post by: k100 on August 13, 2012, 09:35:21 AM
so its ok to ues standed vdo typ gauges ? yes _no our do i have to find genuwe bmw typ
 :dunno :dunno
Post by: mystic red on August 13, 2012, 09:38:38 AM
 :dunno :dunno
YES, I have one in my bike. Needs a different sending unit but I just got used to where it reads and left the OEM in.
Post by: k100 on August 16, 2012, 04:56:19 AM
ok my bike is an 84 and has nun of the wiering thas showen < now what ?  :dunno2: :yikes:
Post by: k100 on August 16, 2012, 05:01:11 AM
i serpous the fuel gage is out of the question now ?  and is there a vdo water temp sender that will fit ?
 :confused:
