TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: TimTyler on August 10, 2012, 01:13:04 AM
What's the smartest way to upgrade the oooold brake hoses on my ABS K75?
Replacement hoses from the dealer? Online retailer?
I have some from Speigler. Great service from them. Got a few on clearance from a K75 T (C bars), and ordered a rear set and one for the high bars (they called me, and had me check the length, to make sure I ordered the right ones) directly from them.
Bob's sells them for $169
http://store.bobsbmw.com/product/ss-brake-hoses-k75-1988-91 (http://store.bobsbmw.com/product/ss-brake-hoses-k75-1988-91)
+1 on Speiglers.
I have them on the '95.
You should have said you thinking about them, you could have looked them over at the cabin.
I also replaced my 20-year old OEM brake lines on spec with Speigler. Those are C-bars with barbacks, so the boys at Speigler custom made a line for my bike at no extra cost. I measured what I wanted using a piece of nylon cord.
(http://i1110.photobucket.com/albums/h448/ghyber/DSCN9701.jpg)
(http://i1110.photobucket.com/albums/h448/ghyber/DSCN9705.jpg)
Any local shop (http://www.spokanehose.com/) can build a set of brake hoses. Just pull yours and take them in with you.
All good advice. Thanks.
Replacing break lines is my next move assuming I recover gracefully from the rear main seal / all-spline lube job I'm wrapping up now.
Any? There's a bunch in Seattle that won't.
F off. I guess I haven't coooled off yet. :neener:
OK, call around and find a local shop to do it. Seattle has to have one.
I took mine to a Hydraulic shop that has the machines for doing the crimps. 5 hoses, all braided stainless, banjo fittings oriented in the right direction, and a hand full of seal rings. They must have thought I was a real klutz, I had enough seal rings to do three bikes. All in all $123.65. I drop them off on my way to work in the morning and picked them up on my way home that afternoon. I thought it was a good deal.
