TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: jeffhestand on August 06, 2012, 11:41:35 AM
i was wanting to replace my anemic horns on my 85 K100 with some blasters... Can i just direct replace them or do i have to have special wiring etc....??? Thanks
K bikes already have horn relays, so you should be good. I'd bump the horn and cooling fan fuse up to 30 amps, though. I had to hit the horn (stebel nautilus, modified for a remote pump) while running hard (95mph) in 100 degree weather. Cooling fan must have been on, so it honked, and then stopped, and I started getting the coolant light when I would wind up to pass.
which fuse is the one in question and thanks
#7
