TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: 2slow on August 03, 2012, 04:31:45 PM
Title: Handlebar pad switches
Post by: 2slow on August 03, 2012, 04:31:45 PM
Has anybody found aftermarket switches that will fit into the stock cut out's on the handlebar pads it's for an 85 k100  thanks
Title: Re: Handlebar pad switches
Post by: Opus on August 03, 2012, 06:13:46 PM
You can use a lighted switch but you may have to shim it in place with some foam tape.
I was looking at that for my running lights. So far I have not found them with out going through a dealer.
Post by: argent brick on August 03, 2012, 11:22:20 PM
Mount the switch into the stock cut cover. That way you do not have to use any foam tape; and it is easy to make it "stock" again.
Post by: Scott_ on August 04, 2012, 01:49:22 PM
If I understood what you said, basically buy a narrow enough switch and cut the "stock blank filler" to fit the narrow switch in it.
I did this for my running lights and fan switch's on both of my LT's.
Plenty of blank switch positions on them.
Post by: argent brick on August 05, 2012, 03:02:13 AM
You understood just fine. Personally, I would consider a push button switch over a rocker style.
