It's happened to me a few times just because of bad technique. Really get that shift lever to the top of its travel when jumping to 2nd and hope that you've just been lazy lately. :2thumbup:
One other thing I have seen do it is the splined spacer behind the driven gear cracked in half and fell into the bottom of the box slowly followed by the dogs on the drive gear as it disentergrated bit by bit. It was a real big mess by the time he got home.
Did you lube the clutch spline or just the drive shaft splines?
I went as far as taking off the swing arm and the next piece, I think is the transmission housing? and lubed the male spline that sticks out of there. Are you telling me I needed to go deeper into the transmission? I didn't see a write up on that.
Regards,
Larry
What are the usual RPMs to use when downshifting from gear to gear?
