TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: kjel-man on July 22, 2012, 05:45:29 AM
Title: Tail light problem K75S 1990
Post by: kjel-man on July 22, 2012, 05:45:29 AM
Hello!
I have a strange problem with the taillight on my 1990 K75S (ABS). When I put the ignition switch to parking light, both the backlight and front bulb light up as it should. When I put the ignition switch in the start position, both bulbs turn off.
Does anyone have an idea what this error might be?
Kjell
Title: Re: Tail light problem K75S 1990
Post by: Inge K. on July 22, 2012, 06:42:23 AM
Welcome Kjell!
If your cluster light shows when ignition on, the problem is in the ignition switch.
If the cluster light doesn`t show, the problem is in the light on/p/off switch.
Ignition switch dismantling. (http://www.seeger-sv.de/ANLEITUNGEN/zuendschloss.pdf)
Inge K.
Post by: kjel-man on July 22, 2012, 09:51:47 AM
Thank you Inge K!
The ignition switch is brand new. The cluster light do not shows, so it must be the light on/p/off switch.
Kjell
Post by: Inge K. on July 22, 2012, 12:58:04 PM
RHS switch assy dismantling. (http://k-technik.pytalhost.com/pdf/killschalter.pdf)
The problem could also be in the switch assy connector under the tank,
the grey/blue wire is the park/tail/cluster feed, measure at both sides of the connector.
Inge K.
Post by: kjel-man on August 02, 2012, 07:40:40 AM
Problem fixed!
Thank you Inge K
Kjell
