TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: lukeman on July 05, 2012, 11:14:22 AM
Title: Should bike stall, cover air intake.
Post by: lukeman on July 05, 2012, 11:14:22 AM
I'm still going through the process of finding vacuum leaks in on my 85 K100.  Should the bike stall if I completely cover up the air intake on the air box where the cold air intake normally connects?  I would just like a definitive 'yes' its not leaking anywhere.  I covered mine and bike still ran as normal which doesn't give me a good feeling...   :hmm:
Title: Re: Should bike stall, cover air intake.
Post by: Scott_ on July 05, 2012, 05:37:12 PM
Well, ideally it should make a difference, but realistically, probably not.
The bottom connection of that intake scoop, at the bottom of the airbox, is not a very tight fit at all, so you are most likely leaking air into the airbox at that point.
Post by: lukeman on July 06, 2012, 09:51:15 AM
Ok cool, yeah it made no difference really.
Thanks.
