TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: frankenduck on June 24, 2012, 09:36:46 PM
Title: Hard to see oil level in sight glass window
Post by: frankenduck on June 24, 2012, 09:36:46 PM
Somebody PM'd me the following:
Quote
I cant tell where the oil level is in the window it looks the same all across. so either its very empty or overfilled.
The first thing to do is put the bike on the side stand.  You should see either no oil in the sight glass window or maybe just a little at the bottom. It should look about like this - but without all of the bird guts on the side of your bike. :yes
(http://home.comcast.net/~smithduck/tours/bmw8/bmw8_album/slides/b8_1472.jpg)
Oil sight glass windows can:
a) become very crazed so that its hard to see the oil level (sometimes using a good bright flashlight can help you see through a hazy sight glass)
b) become very dark so that, again, it's very hard to see through them
If you determine a) or b) is the case then its time to install a new one.
If you're not sure how much oil is in your bike (over-filled or under-filled) then drain the oil and change the filter.  Watch the oil sight glass window as it drains to see if you can see the oil level going down. If you can then you probably had too much oil in the bike.
After you've changed the filter and buttoned things back up, add about three quarts of oil.  Slowly add another 2/3 of a quart while watching the sight glass window.  If you don't see the oil level rising as you add oil then you need probably need to install a new sight glass window.
After you've refilled it remember to run the bike for a minute or two to fill up the oil filter, then turn it off and let it sit for ten minutes and then check the oil level again.
Title: Re: Hard to see oil level in sight glass window
Post by: GasStation on June 24, 2012, 09:55:35 PM
Man o' man you must be "really flying" with that K-bike to have a bird strike.  :yow
Gas
Post by: mystic red on June 24, 2012, 10:50:51 PM
It's a known fact, Ducks kill robins. :eek:
Post by: frankenduck on June 24, 2012, 10:56:14 PM
Just cruising along at 70.  Saw a bird come in from the right, didn't see him exit to the left.  Thought it was a bit odd at the time but didn't realize I'd killed it until I stopped to camp and saw blood and a few feathers on my boot.  I'm glad it decided to fly into the "crash" bar.  Probably would've hurt if it had hit my leg.
Post by: orthomini on June 29, 2012, 11:57:16 PM
well now that ive changed the oil etc i can easily see the oil line in the window. thanks for the help
Post by: frogy on July 01, 2012, 12:20:17 PM
Learn somthin new everyday on this site :hehehe
