TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: tsbt on June 15, 2012, 12:39:41 PM
I'm trying to remove the Oil Pressure Switch Cable so I can reseal the Timing Cover that leaks and check the Front Oil Seal while I'm in there. So far with a little coaching from Frankenduck, I've got two maybe three options.
1. figure out how to fit these two cables through the tiny hole at the top.
2. Cut and splice the wires back together.
Or 3. let my timing cover dangle (not easy if I'm applying new gasket compound.)
Has anyone got a better procedure for this? I've also attached the page from the Repair manual however BMW doesn't describe it either. Am I missing anything?
Also looking for one of those fancy BMW Seal Tools, heard the seal is a b*tch to replace properly without one if anyone knows where I can get one.
UPDATE: I have a feeling Frankenduck explained this but I misunderstood, was a simple procedure getting these wires out of the way. Unhooked the Oil Pressure Switch Cables under the bike (thought for some reason these were different wires because their direction was hidden by the Oil/Water pump cover, newbie move :tongue) can't quite fit the cables with the rubber sleeves through the Timing cover, oiled them up good but didn't want to force it. Was doing this so I could clean the cover but no luck, whatevs.
Trouble was, I made the mistake of NOT Gunking the engine thoroughly before removing the Timing Cover/radiator, then tediously had to clean the edges with Gunk and paper towel to avoid dirt getting into the gears and chain. This gave me time at least to examine and understand the inner workings of German engineering :mbird and from what I can tell everything looks to be in great shape. Timing chain and sprockets are tight, minor wear on the sprockets but I'm sure that's normal. I'll post pictures of the sprockets later.
Also while I've got her open, how important is a Cam Chain Tensioner Depresser?: http://www.motobrick.com/index.php/topic,971.0.html (http://www.motobrick.com/index.php/topic,971.0.html)
If you're just reealing that cover then you don't need to mess with the timing gear.
