TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: dakardad on June 01, 2012, 05:32:58 PM
Title: starter relay location/what can cause a severe batt drain?
Post by: dakardad on June 01, 2012, 05:32:58 PM
OK, Im new here, seems my starter relay is fused after a low volt batt was replaced on my 93 k1100lt.
Where is it?
best part to replace it with?
Thanks, John
I fixed the relay and with a new batt it ran great for about 6miles.
then it barely started, acting like a low batt.  Starter or alternator?
When I first started it up the dash batt light was on. went off after a mile or two.
Title: Re: starter relay location
Post by: Inge K. on June 01, 2012, 05:59:24 PM
At rear right in the relay box, under the rear end of the fuel tank.
Inge K.
Post by: frankenduck on June 01, 2012, 09:36:04 PM
Look at the second diagram here: http://www.motobrick.com/index.php/topic,536.0.html (http://www.motobrick.com/index.php/topic,536.0.html)
Post by: dakardad on June 01, 2012, 09:52:07 PM
Thank you both!!!
Got it.
