MOTOBRICK MARKETPLACE => FS WTB WTT ~ Bikes ~ Parts ~ Gear => Topic started by: KCinSB on June 01, 2012, 11:56:12 AM
Title: Need '93 K1100 trans shifter SHAFT, Yep, the shaft!!
Post by: KCinSB on June 01, 2012, 11:56:12 AM
OK, some time back I bought a '93 K1100RS with no title as a parts bike. I get it, started it, and could not make sense out of stripping it. It has some damage, not really horrible, but one real PROBLEM.......   :dunno2:,  the trans shifter shaft is broken off flush with the trans case.  I know,............  how the heck could that happen ????    :hmm:    The bike did go down on that side, but the surrounding parts and exhaust don't show the required evidence, very odd.  So, after the backround, I was wondering how hard it would be to take a trans apart and replace that shaft............   15 - 20 minutes???     :giggles    Anyone have a junk trans with the shaft still OK ?
 I have pretty much given up trying to get a title for the bike, which should not be as hard as the CA DMV makes it. So I'm back to thinking of it as a parts bike.
Title: Re: Need '93 K1100 trans shifter SHAFT, Yep, the shaft!!
Post by: Scott_ on June 01, 2012, 04:39:04 PM
Well, if you are not in a big hurry, Gwen(Shoganai) is doing a transmission rebuild. Making 1 good trans out of two bad ones.
1 had a bad input shaft, the other had a bad gear for 2nd gear.
She might be able to make you a deal on the part's you need when she's done.
She's only doing this in her spare time, so I can't exactly say when she will be done.
She has a thread started in Tech.
http://www.motobrick.com/index.php/topic,1808.msg9721.html#msg9721 (http://www.motobrick.com/index.php/topic,1808.msg9721.html#msg9721)
Good luck.
