TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Mitcam62 on May 21, 2012, 12:17:26 PM
Title: Clock on '94 K75 Will Not Keep Time
Post by: Mitcam62 on May 21, 2012, 12:17:26 PM
The clock on my '94 K75 will not keep the correct time. WTF? I have reset it several times but, no dice. I like the 24hr feature but it does me no good since I can't trust it. HELP!!!!
Mitch
Title: Re: Clock on '94 K75 Will Not Keep Time
Post by: mystic red on May 21, 2012, 12:33:58 PM
Haven't heard that one before. Is it resetting like it has lost power? Or does it just run slow or fast?
Post by: Mitcam62 on May 21, 2012, 01:08:30 PM
Runs slow. I reset it at 1300 2 days ago and now it should be reading 1207 local time but it's reading 1302!
Mitch
Post by: Mitcam62 on May 21, 2012, 01:11:15 PM
Correction, it's reading 102
Post by: mystic red on May 21, 2012, 01:38:37 PM
If it loses power I think it resets to 00:00 and starts counting. You can try cleaning the cluster plug and reseating it. If that doesn't work you'll have to take the cluster apart and check the internal connections.
Post by: frankenduck on May 21, 2012, 02:06:02 PM
I doubt it's the internal connections given the way it's connected.
Do it flicker at all when you're riding?
Post by: Mitcam62 on May 22, 2012, 10:42:14 AM
No Duck, it just refuses to keep accurate time. I tell you this clock is driving me nuts! I have a brand new BMW Branded (EXIDE) Gel Battery, alternator is working fine & all other electrics are perfect. I'm starting to think it's just straight-up Gremlins!
Mitch
Post by: frankenduck on May 22, 2012, 11:06:25 AM
Sounds like you just have a bad clock.
Post by: Rick G on May 22, 2012, 08:00:58 PM
You can get new ones on fleabay http://motors.shop.ebay.com/i.html?_nkw=BMW+K1100+clock&_sacat=10063&_dmpt=Motorcycles_Parts_Accessories&_odkw=BMW+K1100&_osacat=10063&bkBtn=&_trksid=p4506.m270.l1313 (http://motors.shop.ebay.com/i.html?_nkw=BMW+K1100+clock&_sacat=10063&_dmpt=Motorcycles_Parts_Accessories&_odkw=BMW+K1100&_osacat=10063&bkBtn=&_trksid=p4506.m270.l1313)
I fixed one on a mates K100 by cleaning the contact area with a pencil eraser, it's still working but it was just not working at all
Post by: Inge K. on May 25, 2012, 07:02:42 PM
Try to disconnect the battery for about a half hour (did work for me...opposite problem...running to fast).
Inge K.
Post by: frodef on June 12, 2012, 04:42:20 AM
There's a trim capacitor on the clock unit if you pull it out from the instrument housing. I believe it's supposed to adjust the clock's timing. I've never tried this myself, but I suppose it's worth a try to fiddle with it. You'd want to hook up the clock to some external 6V power source while you do the fiddling, I imagine.
Post by: Inge K. on June 12, 2012, 06:01:56 AM
This is only valid on early units, the chip and pcb was changed.....around -89 -90 somewhere.
On the later unit the trim capacitor is removed.
Inge K.
Post by: frodef on June 13, 2012, 08:11:27 AM
Well then, for the OP I have a proposal then... I have clock that I think keeps time reasonably well (and FWIW its got a trim cap), but the LCD display is dead. So put together I suppose we have one functional clock  :bmwsmile  Would you be interested in my clock "back end"?
Post by: Inge K. on June 13, 2012, 10:14:03 AM
Frode, have you seen this (http://www.ibmwr.org/ktech/lcd-clock-fix.shtml)?
Inge K.
Post by: healthy on June 13, 2012, 03:04:04 PM
haha, i have both of you "beat"
(https://lh6.googleusercontent.com/-9gRBdOWy-nU/T7L2al55V7I/AAAAAAAAhNc/cpB8DW1nFTY/s400/IMG_20120515_193520.jpg)
just got the bike a little while ago, as you can see, the LCD is busted on the left hand side.
"oh, well i can see most of the hour, and the minutes so no big deal."
recently realized that the time is getting more and more off. so yeah, useless.
next time i have the cluster open, i'm going to make notes of how much space is taken up there. perhaps i can figure out some circuit i can build to fill the space and give me back a clock and maybe more.
Post by: frodef on June 13, 2012, 05:00:25 PM
Yes, I've tried that and more, rubbing the LCD contact points with alcohol and whatnot. Finally I rubbed too much and now none of the segments work...  :dunno
I think a new oem clock is too expensive, I'm going to find some cheap clock thing to put in there, and possibly some custom microcontroller thingy later on.
