TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: thebob on May 06, 2012, 09:59:52 PM
Title: Self retracting stand.
Post by: thebob on May 06, 2012, 09:59:52 PM
I now have in hand the parts to re-fit the self retracting stand. I am having problems finding where to attach it!
I have a whole "used center/sidestand assembly. The spring holder is different to what is fitted to my bike, and the retractor pivot is missing on my bike.
I want to change over my whole used assy, but I can't find where the rod is supposed to attach.
The rod is very similar to a wheel spoke but it has a half moon shaped  stainless "nut".
Any pics or diagrams would be helpful. I'm just hoping that I don't need a special clutch arm as well!
Thanks in advance.
Title: Re: Self retracting stand.
Post by: frankenduck on May 06, 2012, 10:21:28 PM
(http://www.realoem.com/bmw/diagrams/t/q/2.png)
Post by: thebob on May 06, 2012, 11:05:35 PM
I can see that there should be the lever part 1 but where is that part? Attached to the clutch arm?
Post by: frankenduck on May 06, 2012, 11:18:52 PM
It rotates on the clutch arm pivot rod and is rotated to retract the side stand when the clutch is pulled in.
Post by: thebob on May 06, 2012, 11:36:52 PM
Arggh I dont have that part or the extension on the clutch arm pivot rod to mount it!
Is part No 11 the same on all bikes?
(http://realoem.com/bmw/diagrams/j/w/5.png)
http://realoem.com/bmw/diagrams/j/w/5.png (http://realoem.com/bmw/diagrams/j/w/5.png)
Post by: frankenduck on May 06, 2012, 11:58:56 PM
Yes:
http://www.realoem.com/bmw/partxref.do?part=23131451124 (http://www.realoem.com/bmw/partxref.do?part=23131451124)
Post by: thebob on May 07, 2012, 12:02:31 AM
Thanks it looks like I need to find parts 123 and 8 from your diagram.
Post by: frankenduck on May 07, 2012, 12:24:31 AM
You already have part 8.  It's a needle bearing inside the clutch lever.
I think you need to see a picture of how things work.  I'll see if I can get you one tomorrow.  Maybe some video if possible to help you understand things a little better.
Will be more helpful than looking at parts diagrams where everything is in pieces.
Post by: thebob on May 07, 2012, 05:59:38 AM
Thanks. It is a bit difficult to work out which parts have been removed.
In this picture is it standing upright, in line with the left leg of the center stand and visible above and below the clutch arm?
(http://i1221.photobucket.com/albums/dd470/Motobrick/splinelube/k75F_tranmission_back.jpg)
Post by: frankenduck on May 07, 2012, 03:36:36 PM
Yes, that's it.
Here's one I took off of a K75 trans last week.
Post by: thebob on May 07, 2012, 06:46:34 PM
Cheers I just found this one on the auction.
(http://auctions.c.yimg.jp/f30batchimg.auctions.yahoo.co.jp/users/7/7/4/4/bst2222222-imgbatch_1326939254/600x450-2012011700094.jpg)
It's from a K75S
Post by: frankenduck on May 07, 2012, 07:01:01 PM
Yep, that'll do ya! :2thumbup:
Hint: Before you install it regrease the needle bearings in the pivot hole through the clutch lever to keep clutch operation as smooth and easy as possible.
Post by: thebob on May 08, 2012, 02:03:27 AM
Thanks.
