TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: monty8563 on March 02, 2012, 03:51:35 PM
Hi all,
have been trying to adjust my handle bars on ,my k1100rs, started with the l/h/s and found the small alen bolt backed it off a bit and turned the cluster with no problem, tryed to do the same on the r/h/s master cyclinder side and I CANNOT FIND THE BOLT please can someone tell me how to do this side or find the fittings thankyou in advance monty
Remove the combo switch. Be careful undoing that Phillips screw. Use a good screwdriver so you don't strip the head.
Also, don't overtighten the bolts that clamp the perches to the bars.
Thanks for the info, have now done the job, you were right about the phillips screw had to drill it out as someone before had rounded it off
