TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: DRxBMW on February 28, 2012, 07:39:59 AM
Title: Seafoam Vs Chevron Techtron
Post by: DRxBMW on February 28, 2012, 07:39:59 AM
Any comments on Seafoam cleaner Vs Chevron Techtron FI concentrate Duck,JO ?
1987 K 100 RT occupying space in my garage currently, it does run a bit on the rough side,stumbles some at idle. Fresh petrol and a fuel filter R&R on the slate for this morning.
IMHO, the bike simply needs to be ridden more. Plan is to go wring the piss out of her this afternoon, see what happens next.
dunno, I'm NOT a big additive fan per say but for bricks that sit, probably a good idea.
The only additive I use on my whip is Startron to defeat alcohol poisoning.
Rumor mill that the Techtron concentrate is the ONLY FI cleaner that actually works. (Tom Cutter)
For the record, I've NEVER used Seafoam period. Does it really do anything ?
thanks _______________________.
Title: Re: Seafoam Vs Chevron Techtron
Post by: johnny on February 28, 2012, 07:44:08 AM
12oz techron... 1st 1/2 in a full tank... 2nd 1/2 in next full tank...
Post by: 552255 on February 28, 2012, 10:26:04 AM
I've used Seafoam in all engines as fuel additive...in a carbon fouled rough running buick, it "fixed", and in all my small engines--they start on first pull usually.  Works as stabilizer too.  I'm sure the Techron will do just about the same...go with whats available and on sale!?  Seafoam has gotten a tad pricey lately...not as much as Bk44 tho.
Post by: frankenduck on February 28, 2012, 10:53:34 AM
My thoughts are:
Techron for fuel injected engines. Seafoam for carb'd.
Post by: Lawrence on February 28, 2012, 11:46:34 AM
I strongly recommend that you avoid stronger concentrations of seafoam or techtron.  Follow the directions on the package!
Post by: DRxBMW on February 28, 2012, 08:18:35 PM
My thoughts are:
New NAPA fuel filter,$18.00 worth of premium petrol and 120 miles later, this K 100 is finally running better. GREAT weather, the RT offers more protection than my Parrabellum Scout wind screen on the K 75.
Upon my return, I synched the TB's, idle has smoothed out.
R&R with Bosch "dual electrode" spark plugs (XR7LDC) to replace the older (X5DC) single electrode model currently in the bike this time around.
Picked up a bottle of Techtron, can't hurt to treat the fuel system.
Called the owner and informed him his bike is ready,bring your checkbook.
Convinced most of the roughness was old gasoline and lack of motor activity,read ride hard.
Post by: orforester on February 28, 2012, 10:05:04 PM
Real time, seafoam on sale at K-mart for $6.99 this week.  Pretty cheap and time to stock up. Couple of months ago, NAPA had it on sale for same price.
Title: is seafoam safe for the crankcase?
Post by: branandfox on April 24, 2014, 02:44:03 AM
I see on the bottle of seafoam that is registers as a Crankcase cleaner as well as a fuel systems cleaner. I will start using it to keep the fuel system clean as soon as my bike is back together in the coming week or two but what about the crankcase? is it safe to run a relatively low amount of seafoam per qt for 30-50 miles/minutes before changing the oil and filter? and if so does it produce results? Id like to know any reviews people may have or suggestions before I dump anything into my crankcase!
Title: Re: is seafoam safe for the crankcase?
Post by: Jumpin Jimmy B on April 25, 2014, 12:18:00 PM
From the web....I've done this on bikes that have sat a long time. Always make suer the oil level is correct and NOT low.
Using Sea Foam Motor Treatment in crankcase oil
Sea Foam Motor Treatment may be used in an oil crankcase two separate ways, depending on your needs and expectations. Sea Foam Motor Treatment is most commonly used as a pre-service, old oil residue re-liquefier / cleaner. It can also be used as an after-service oil additive. In either application, Sea Foam Motor Treatment will safely and slowly re-liquefy old oil residue. Each method is described below:
 ■As a pre-service cleaner for old oil residue, (and to address valve train noise and timing chain hydraulic tensioner noise), pour 1 ½ ounces of Sea Foam Motor Treatment into the engine oil crankcase for each quart of oil capacity, including filter. Drive a minimum of 30 minutes (a maximum of 100 miles), and then do your oil change service. This begins the process of safely/slowly re-liquefying the old oil residue so contaminants may flow and be filtered away. Your old oil will quickly become much dirtier, so an oil change service will be necessary soon after this pre-service treatment. This is also a great idea for turbocharged and supercharged applications where oils deteriorate so quickly due to heat, leaving those residues that need cleaning.
 ■As an after-service additive for fresh oil, nearly fresh oil, or used oil that is NOT yet ready to be changed (based on mileage since last service). Add the same amount of Sea Foam Motor Treatment to the crankcase as described above, and then regularly monitor your oil for color and clarity. Set a predetermined schedule for checking the oil condition on a mileage, timed, or event basis (such as every time you gas up, etc.) to determine when an oil service is necessary. Monitoring of the oil for color and clarity will tell you when it is time to do an oil change service. NOTE: Do not exceed 3,000 miles without changing the oil.
Remember, Sea Foam Motor Treatment is safe to use with all synthetic oils. Purely synthetic oils, and blends of synthetic and petroleum-based oils, were engineered to be 100% compatible with petroleum-based oils of all brands, and vice versa. Without this compatibility, oil manufacturers and engineers would be liable for the results of mixing non-compatible lubricants. Since Sea Foam Motor Treatment only contains petroleum-based oils, it is entirely compatible with synthetic oils.
Remember, when using Sea Foam Motor Treatment in your crankcase:
 ■Check your oil and monitor its color & clarity to determine need for oil change service!
 ■Change your oil when it gets dirty!
Post by: drut on April 25, 2014, 12:58:34 PM
Have used Wynn's oil flush with good results when I bought a car with filthy oil but with good oil & regular changes the detergents in modern oils seem to do a good enough job for me.
https://www.youtube.com/watch?v=nZQFoDX8egE (https://www.youtube.com/watch?v=nZQFoDX8egE)
Post by: branandfox on April 27, 2014, 03:42:29 PM
Jimmy, On those old barn finds how did the treatment work out for you and which treatment did you do? I am thinking of doing a preservice treatment to help clean out any crud especially coming out of a long winter for me.
Post by: Jumpin Jimmy B on May 18, 2014, 08:53:43 AM
 I am so sorry, I never checked back. PM me if you need a more immediate response.
Works great. Add the Sea Foam, go for a nice long ride. 100 miles is  this goal. Good mix of city & highway.
 Go home & park the bike. Next day short ride 20 miles to warm it all up.  Really clears the old gunk out
GENTLY!!! It needs to dissolve NOT fall or break off in chunks.
Now change the oil & filter.
 Run the new oil & filter for 1,000 and change it out and proceed to your normal schedule.
Unless the bike has been sitting a long long time this isn't really needed.
 The K1100RS I bought got only 2,000 miles in 8 years. The bike ran fine, would not pull strong after 5,000 RPM.
 I did a bus & ride. So, stopped for fresh gas, added Sea Foam to gas, got within 100 or so miles of home and added a good splosh to the crank case.
 Within an hour and a half of adding to the gas bike pulled clean and strong. Might have been just old gas too. Got home and let it sit, rode the next day to work, then the long way home and changed oil. Bike runs good and for the motor has been problem free for over 40,000 miles.
 Good luck.
Post by: K75RT Keith on May 18, 2014, 09:03:02 AM
Yes,   Follow the recommended mixture and ride it for a good couple hundred miles of mixed riding (city & Highway).  I agree with Jimmy, it does seem to work better if you let it sit   I put it in and did a 3 day trip (about 1500 miles)  then changed the oil and filter with good results.   If you have a "Barn find" I'd suggest having the injectors cleaned rather than just relying on an additive.  Mine had sat for 3 years and Sea Foam worked ok, but a cleaning by Mr. Injector, made a huge difference.
Post by: branandfox on May 19, 2014, 08:12:29 AM
I actually have remanufactured injectors. 4 pintle instead of single pintle injectors which are pretty new.
Title: Seafoam
Post by: kryder on June 15, 2015, 06:28:13 PM
Seafoam is a product that has been around since the 30's that many swear by. I am a fan. I recently rode my R1100S on a longish trip and started developing a stall after switching on the ignition and giving the S some gas. It got progressivly worse and in a short time was a safety issue, as no one wishes to stall and try a restart in heavy traffic. I suspected a fuel issue and added one half can of seafoam to a full tank of fuel. In short order my dying bucking engine smoothed out and now runs as of yore. The next time I get fuel for my Kryder I'll do the same with it. Seafoam also can be added to the crankcase or fuel intake on automobiles. My point is, if you're experiencing something similar to my situation before you look elsewhere give this product a try.
Title: Re: Seafoam
Post by: Brad-Man on June 17, 2015, 12:05:30 AM
I bought my stepson a '90 Camry 4 cyl. auto for not much that did not idle well in gear after new plugs, wires and throttle body cleaning.
Did the Seafoam treatment (per directions for cleaning the top end) and it was butter smooth afterwards.
Just sayin'...
I'm sure there are other chemicals/brands out there that require more $ and/or professional labor to provide the same results, and I'm sure there are ignorant and non-mechanically inclined people that will go with these products/take it to a shop.
I'm not one of ''em.
Title: Re: Seafoam
Post by: The Mighty Gryphon on June 17, 2015, 02:57:10 PM
I use Seafoam in all my gas engines.  My generator, lawn tractor, boat engines, k-bikes, snowblower, chainsaw.  The longer they sit idle the more they need Seafoam.  Seems like modern gas blends don't age well and varnish out faster than the old school blends.
Title: Techron Concentrate Heads up
Post by: bizzaro on August 09, 2015, 03:37:22 PM
So I don't know if it is nationwide, but NAPA is having a great sale on Techron  Concentrate.  I just paid 3.49 for the 12 oz. bottle in Vermont. Not sure how their sales run,(region, nation, state), but that is "cheap". I got four bottles.
Title: Re: Techron Concentrate Heads up
Post by: The Mighty Gryphon on August 09, 2015, 06:05:42 PM
Thanks for the heads up.  Will have to check my local NAPA store.  The Carquest in town has two 12oz bottles for $10.  Just recently was paying $5.89 for one bottle.
Post by: TimTyler on August 09, 2015, 08:06:08 PM
Just watched this. The take-away is not good.
http://www.youtube.com/watch?v=h8i9qftqKNY
Post by: Scott_ on August 09, 2015, 11:33:02 PM
Interesting SeaFoam had the best results......
Post by: bizzaro on August 10, 2015, 08:42:36 PM
Good to know Tim! Thanks.  I am always suspicious of additive claims.   Love guys that take the time for this kind of testing.  I had never used Techron before reading about it here at motobrick being a great product.  I used to use Sea Foam a lot in another bike, but then read somewhere that it has ethanol in it. IMO the last thing an engine needs is more ethanol!  Both products seem to make my engine run smoother at any rate? And I am back to trying Sea Foam because of Scotts post's.  Like I said. They both seem to make my K run better.  I also use a little Marvel Mystery Oil now and again.
Post by: richarddacat on August 10, 2015, 08:44:16 PM
Thanks, always preferred this stuff but looks like it's another snake oil.
Makes me wonder if these fuel stabilizers actually work. I always try to run my lawn equipment empty but add something to the bikes.
Post by: TimTyler on August 10, 2015, 08:49:23 PM
I suspect the YouTuber's results might have more to do with the application than the formula.
The whole can of Seafoam gets burned in five minutes while the bottle of Techron added to the tank takes hours.
That's not really an excuse though.
Results might be different on motorcycles too since I bet out engines run hotter. Makes me want to get a borescope camera and check out my pistons.
Post by: orforester on August 10, 2015, 10:26:58 PM
I think I use Techron more to clean out the injectors, not the carbon build up?  I know it runs better after a shot of the stuff.
As far as Sea Foam, I ride with a Carb bike guy and he has some troubles in the past, a can of sea foam clears it up?  Could it just be a better tank of gas, maybe, but I know if you leave it in a Carb, it is clearly more shiny afterwords!
Seat of the pants, and it don't hurt!
Bob
Post by: MonkeyMcBean on August 10, 2015, 10:39:45 PM
I have a feeling that the tech Ron does more for the injectors than anything else. Sad to see he didn't test his injectors.
Post by: petermarek on August 14, 2015, 06:07:04 PM
Advice would be nice. I refurbed a '85 K100RT bike and got it started on "regular" gas 89 octane. I heard the knocking, so siphoned the tank and replaced it with Shell Nitrogen 93 octane "Premium" ("may have upto 10% ethanol" here in MD, USA; what am I gonna do). Bike runs Great! No knocking, smooth acceleration, no backfires, etc.
Why do I need a product like SeaFoam or Techron? Bike is only nearing 14k original miles - it sat under a carport for ~20 years, lots of cleaning, all new rubber, a new fuel pump and injectors (refurbished) and it started.  :bmwsmile
Thanks,
Post by: MonkeyMcBean on August 14, 2015, 06:36:42 PM
With new injectors, you probably don't need techron.  depending on how many miles you put on in a year, you might not want to use it for another 20k or so. You will want to use something to stop the water from becoming a problem. water WILL get in your tank. Even if your bike never gets wet. You'll want to run a fuel additive to help with ethanol and water problems at least once a year.
Post by: johnny on August 14, 2015, 07:29:32 PM
techron... seriously as a fuel additive... ha ha ha... i drink it... used to drink shots no chaser... butts these days itsa small cold coffee glass filled with ice cubes... 1 1/2 shots of techron... top it off with red bull...
the whole shebang can be had at truck stops for cheap... two and on the road...
Title: Re: Seafoam
Post by: TimTyler on September 10, 2015, 06:38:20 PM
If you can't find Seafoam you can always use expanding foam.
Title: Re: Seafoam
Post by: The Mighty Gryphon on September 10, 2015, 11:03:42 PM
I recall someone telling me that Seafoam is great stuff...
Title: Re: Seafoam
Post by: Chaos on September 11, 2015, 12:21:42 AM
Never used it. Seems to be one of the better regarded additives.  Maybe if I got a used vehicle and couldn't get it running right, but MMO  for it's marvelous mystery ingredients and Heet to remove water usually work and are cheaper.
I may try the expanding foam to plug some leaks.  Do you suppose it should go in the gas tank or the sump?
Title: Re: Seafoam
Post by: K75RT Keith on September 11, 2015, 10:36:22 AM
I use it on my K at the beginning of the year.  It seems to help clean out what ever gunk has built up in the injectors. Also have added it to the oil in my old bike and taken a long ride before an oil change.  it seemed to work ok cleaning up the sludge from the p.o's poor record of changing oil
Post by: johnny on October 22, 2015, 03:26:09 PM
october special at advance autoparts...
cheveron techeron 2 bottles for 8 dollars...
yeeehaaaa...
Post by: SmilingRide on November 28, 2016, 07:33:24 PM
I'm still looking to understand the applications of products. Sounds like the Seafoam cleans up a system of its been running rough and is a one-time or occasional major cleanse. The other products in the photo seem for maintenance and making sure the ethanol doesn't junk up your bike in the first place. Interested to hear your experience. Thx.
Post by: Laitch on November 28, 2016, 09:43:04 PM
I don't use either in my bike and so far, it runs acceptably.
Post by: The Mighty Gryphon on November 28, 2016, 10:09:14 PM
Two years ago I bought a K100 that had not been used for several years.  It ran, but not very well, it was rough and lacked in power at higher speeds.  It had a few issues with the dreaded sprag.
I did an engine flush with cheap oil and a bottle of SeaFoam, and the sprag has worked properly since without any further attention.   I didn't think the power and roughness was bad enough to justify the effort to pull the injectors and clean them on the bench.  Johnny was pretty high on this Techron stuff and Italian tuneups, so I decided to give it a try.  One bottle through two tanks and the engine had gotten smoother with a marked reduction in handlebar vibration.  A bottle per month through the summer and today the engine has better power and the vibrations are now down to where it's almost as smooth as my K75's.  It starts instantly and has a smooth, steady idle whether cold or hot.
Post by: Laitch on November 28, 2016, 10:15:24 PM
If Gryph says it works, it works. After that ringing endorsement, I'm now considering using it too, if he'd send me a couple of cases.
Post by: The Mighty Gryphon on November 29, 2016, 12:43:19 AM
Laitch, you're on your own, if you've been good maybe Santa will bring some for you.  Might make a good stocking stuffer.
Original poster asked about experience.  I was just recounting how it worked in my K100.  Techron gets the varnish out and is less work than pulling the injectors.  If it sounds like I was pleased at how it works, well, I was.
I recently worked as a mechanic in a boatyard where boats were stored for up to 6 months of the year.  A lot of them use ethanol blend gas, and I spent a lot of time pulling carburetors and cleaning the crap out of them.   I tend to think that modern gas doesn't store as well as earlier blends, and anything that helps minimize the grief that old gas causes is worth using.
Post by: Laitch on November 29, 2016, 08:02:16 AM
You don't need to ship me the actually product, Gryph. I'll accept O'Reilly gift cards, to make it easy for you. I'm not that considerate to everybody, although I'm striving to be.
Post by: The Mighty Gryphon on November 29, 2016, 09:01:19 AM
Well, that attitude will certainly move you closer to the top of Santa's "nice" list.
Post by: Laitch on November 29, 2016, 09:15:51 AM
Goodness is its own reward but its affect on gasoline residue is not substantiated.
Post by: K1300S on November 29, 2016, 03:34:10 PM
there are lots of internet opinions on seafoam....everything from total snake oil to holy grail.  i have never used it, nor intend too.
techron on the other hand, works.  i keep a case on hand and use it in all my bmw's.  street cars, race cars and bike.   it will not fix really old and abused injectors, but it will prevent them from getting that way in the first place.
I also use STA-BIL in any gas i won't be burning up in a month.  appears to work as all my gas powered tools and vehicles start right up after winter (or summer in the case of the snowblower) naps.
Post by: Laitch on November 29, 2016, 05:38:35 PM
Here's an image of the Sta-bil product I've been using with excellent results for as long as I can remember—admittedly, that can be from two minutes to ±64 years. The main thing is to use the equipment, or replace the treated fuel yearly. My bike gets used daily for six months of the year. My experience with the product is the same as mlytle's.
* Garden-variety Sta-bil.jpg (42.8 kB . 297x576 - viewed 1326 times)
