I haven't done it, but have read something about rolling the bike backwards to help engage the starter clutch sprags, then hit the button to start it.
Maybe in a higher gear(like 4 or 5) so the intermediate housing gears can rotate easier.
My experience with Synthetic was a few more leaks and just as much or more consumption. For the more expensive $ of syn over dino, I went back with the dino. YMMV
Any thoughts on synthetic versus conventional oil?
I read someplace that the K engines did not like synthetic so I always stayed with conventional oil.
".I personally use ONLY Mobil 1 in my K bike, from WalMart, in 15W50, it comes in 5 quart jugs."
I was in our local MalWart yesterday and the weights they offered didn't go up that high. Is everyone else finding that weight there? (It was a good price, BTW).
A thought on bump starting a K, I believe you have to push the starter button when you drop the clutch to activate the fuel pump.
Not 100% positive on this but I think that what activates the fuel pump is not the starter switch but the signal from the Hall Effect sensor when the engine spins.
I bought a 1994 K 1100 RS about 3 years ago, Previous owner told me the there was a starter clutch problem. I put in a new battery and never had any problems until last fall.Has anyone been brave enough to tackle this at home? Anybody have a Utube video on how to DIY :dunno
I have asked around and found a couple of former BMW dealer mechanics. The going quote is 10 hours of labor to diagnosis/fix the problem.
Anyone have any experience with this problem?
The starter turns and occasionally catches. Sometimes it starts but most of the time I crank until the battery starts to get low or give up because it obvious the starter is not going to engage.
I have read that the starter armature/shaft gets gummed up and the spring that engages the starter gear is likely the problem.
The quote from the former owner was $1,500 to get this issue fixed at the dealer. Sounds expensive but this bike is pristine otherwise with about 45,000 miles on the clock. If I were sure I had all the tools I need I would tackle this myself, but it sounds really complex. I do not have a garage to work in and probably do not have all the right tools.
Can anyone offer any assistance with this issue?
I have. About 8 or 9 years ago my K75RT stripped it's splines at 35k. Since I had to replace the transmission anyhow I replaced the bellhousing as well suspecting that the old one might have been out of alignment and the cause of my spline failure at such low miles. Part of this involved moving the starter sprag from the old bellhousing to the "new" (used actually) bellhousing.
It's not really that hard but is a fair amount of labor.
Pm Sent
Somewhere I've got a checklist that I made at the time.
