MOTOBRICK.COM => The MBdotCOM Community Center => Topic started by: DRxBMW on February 26, 2012, 07:57:51 AM
Neat stuff, give your mind a creative blast this morning with a personal composition.
Circuli is a generative musical instrument conceptualized and developed by Batuhan Bozkurt. Hence, make sure your speakers are turned on.
http://www.earslap.com/projectslab/circuli (http://www.earslap.com/projectslab/circuli)
* Circles grow at a constant rate.
* No two circle can overlap.
* Bigger circle pushes and shrinks smaller circle when in contact.
* A circle “pops” and makes a sound when its boundary intersects with the center of another circle.
* The pitch of the sound is determined by the position of the circle on the background. Bigger the hole, higher the pitch.
* The envelope of the produced sound is determined by a number of parameters including final circle size and time of interaction between two involved circles.
An action video:
Circuli - Generative Ambient Sound Generator (http://www.youtube.com/watch?v=J2d23yvDPmM#)
Otomata is a generative sequencer. It employs a cellular automaton type logic I’ve devised to produce sound events.
Each alive cell has 4 states: Up, right, down, left. at each cycle, the cells move themselves in the direction of their internal states. If any cell encounters a wall, it triggers a pitched sound whose frequency is determined by the xy position of collision, and the cell reverses its direction. If a cell encounters another cell on its way, it turns itself clockwise.
This set of rules produces chaotic results in some settings, therefore you can end up with never repeating, gradually evolving sequences. Go add some cells, change their orientation by clicking on them, and press play, experiment, have fun.
http://www.earslap.com/projectslab/otomata (http://www.earslap.com/projectslab/otomata)
