TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: TaosBrick on February 03, 2012, 11:40:46 PM
Title: Fork Boots - Anybody use 'em?
Post by: TaosBrick on February 03, 2012, 11:40:46 PM
I live in a dry, dusty environment, where gravel (and sometimes bigger things) are often spewed from under tyres of vehicles in front, or fly off of trucks coming from gravel pits in the opposite lane (ouch!).
So I'm guessing these would be a good investment, yes? (I am also trying to up my number of posts to actually reach 'novice motobricker' status) :bmwsmile
Title: Re: Fork Boots - Anybody use 'em?
Post by: johnny on February 04, 2012, 12:19:19 AM
greetings motobrick curious taosbrick..
somebody needs to get a fork protection post in the lieberry...
most folks use the rancho brand of shock boot #1952... (http://www.oreillyauto.com/site/c/detail/RAN0/RS1952.oap?ck=Search_N0960_-1_-1&pt=N0960&ppt=C0035)
i use the traxxion dynamics fgk1... (http://www.traxxion.com/ConventioalForkGuardKit.aspx)
Post by: DRxBMW on February 04, 2012, 12:38:25 AM
JO are the Traxxion protectors universal fit ?
website makes NO reference to diameter, so I'm assuming so.
Installed Daystar boots on the GS, damn thing overheated, forced to remove them.
Touratech makes a similar model to your Traxxion but EXPENSIVE. The only difference is, there taller in length. Cloned from Triumph aftermarket I think.
(http://www.touratech-usa.com/media/OwsKhO/01-300-0145-0_kit1.jpg?size=prodfull)
Thanks, I've been in search mode for a solution, as I pound gravel laden tarmac all the time.
Post by: frankenduck on February 04, 2012, 01:16:22 AM
The K75F has K1100 forks.
Post by: DRxBMW on February 04, 2012, 07:45:23 AM
perfect fit on the rs motobrick.. can go a little larger or a little smaller in slider diameter i guess... not very tall but protects the general area of travel...
side view k75f...
Ordered a pair of the Trax protectors for the GS five minutes ago. I think they will fit OK. Plus, the price was right.
Surprised NO one ever invented a "zip lock or velcro" type boot for a motorcycle fork yet. I've seen shorter zip lock models for ATV's before in my travels.
Post by: frankenduck on February 04, 2012, 08:01:46 AM
http://www.ascycles.com/detail.aspx?ID=43209 (http://www.ascycles.com/detail.aspx?ID=43209)
Post by: DRxBMW on February 04, 2012, 09:08:34 AM
I've used neoprene covers on my high end mountain bicycle before with dismal results. Retain moisture,swear they trap the grit worse then leaving the sliders bare naked. Granted, easily removal for inspection purposes though.
Old style R rubber boots on my K 75 whip since she was new. I kinda like the nostalgia GS image factor they portray.
FWIW, my mantra is the clean bare sliders on all my toys with Isopropyl alcohol on a regular basis.
Your biggest concern is a stone that actually chips the slider surface. Rare but it does happen occasionally. Tip, back off if another bike or cage is throwing/spitting stones in front of you if possible.
Consider additional headlight protection if run gravel tarmac with trucks. Sheet of Plexiglass cut to shape with a jig or scroll saw, attached with Velcro dots works well, cheap. BMW HL's are PRICEY !!!
All the frontal zone impact covers are designed primarily for "acidic insect leftovers" seal protection.  NOT really an issue if you wipe them down periodically.
Post by: mystic red on February 04, 2012, 12:03:52 PM
I had the Trax and my seals lasted a year with them on so when I did the seals the boots went back on. I don't like doin' the seals. Damn little clippy thing takes all the fun out of it for me. YRMV
Post by: TaosBrick on February 04, 2012, 09:13:56 PM
Thanks for all the beta, everybody. DRx makes good points, the major thing around here is indeed that piece of gravel or rock from a truck that could chip or even dent the tubes. I'm likin' the plexi-headlite cover idea too.  The Traxxion solution looks good, seems it would deflect the hits where it really counts, for that coupla three or four inches above the seal, and the price is way right. Thanks Johnny  :2thumbup:
Thanks for the additional pics of the FB, FD. I dunno, I think I like the look of the c fairing best. I've always been partial to naked or nearly naked motorcycles. Just me, I suppose. I like the idea of the paralever, but always find myself suspicious of anything that involves a rubber boot. I've had to replace too many cv boots/joints over the years. Cool stuf!
Post by: TaosBrick on February 04, 2012, 09:29:03 PM
Jest checked out the Traxxion Dynamics website, they want 18.95 :yow to ship those leetle, nearly weightless pieces o plastique. I wrote 'em an email and said, huh? you gotta be kidding me. $7 for priority mail to my PO Box and you got a deal. Sheesh.
Post by: frankenduck on February 04, 2012, 10:43:41 PM
The fairings are swappable in short order.  The reason I decided on the K11RS fairing is that my knees FREEZE in the cooler fall/winter/spring temps here.  I'll swap on the C fairing for fair weather use in the warmer months.  It'll now be the FBC - Frankenbike Convertible..... :2thumbup:
That boot is nothing.  They don't wear out and, if they do, are fairly easy to replace.  It ain't no CV joint.
In a dusty environ I'll think you'll be better off with the Trax units.  Johnny had boots for a while and LOTS of dusty crap built up in there.  You need to have breather holes in them and in the dust they'll suck it right in.
Post by: TaosBrick on February 04, 2012, 10:48:01 PM
I get you on the freezin' knees FD, that's when it's time to bust out the SKIS! :yes Still no good weather for Brickin' around here yet, snow is flyin' as I write these lines, possible powder day en Maņanna - yea!
Post by: frankenduck on February 04, 2012, 10:51:17 PM
It also doesn't hurt to oil your forks lightly now and then.  Many times pitting is caused by rust, especially if you're near the ocean where the air is salty.  (Not an issue in Taos, I know.)
Post by: johnny on February 04, 2012, 10:57:41 PM
i wipes downs my forks with automatic transmission fluid... atf conditions the seals and its yeeeeehaaaaaaa...
i switched to traxxion cause my motobrick sits in a parking lot under a moto cover and when the santa anna winds blow my gaters would collect sand and f with my seals...
(http://i236.photobucket.com/albums/ff192/owrstrich/2011/12-02-04%20JackBlack/013.jpg)
(http://i236.photobucket.com/albums/ff192/owrstrich/2011/12-02-04%20JackBlack/012.jpg)
Post by: DRxBMW on February 06, 2012, 08:36:58 PM
Thanks for that tidbit of information Taos.
Any word on the shipping charges yet ?
Ya,$18.95 is OUTRAGEOUS !!!   Reminds me of a ebay scam. BTDT
I'm going to call them on Tuesday morning see what the real story is.
Post by: Uffda on February 06, 2012, 09:18:12 PM
I had the same reaction to their policies.
Figured it was time to add a little protection to my bike's naked forks.  Went to the site, expected to buy, and then stopped cold when their ridiculous shipping charge came up.
Post by: Lawrence on February 06, 2012, 10:52:14 PM
Sand is able to blow in the gaiters through the tiny holes in the bottom that allow their expansion/contraction when the bike is underway?  Are you kidding me?  :loopy:
What part of the Atacama do you live in?
Post by: TaosBrick on February 06, 2012, 11:03:54 PM
Where I live in New Mexico, we have the finest, windblown dust that permeates everything. I've wrapped up engine blocks and other
parts with plastic sheeting and duck (not franken) tape, sealed plastic bags, etc. and the shit gets IN. So I'm with FD and JO on the fork boots full o crap theory.
Post by: TaosBrick on February 06, 2012, 11:11:25 PM
Got this nice little note in reply to my email to Traxxion:
Dan Anderson dan@traxxion.com2:01 PM (7 hours ago)
Charlie,
We generally use Fedex or UPS. Fedex's posted rate to your address is
$16.27, and we add a small handling charge to pay for the box and materials.
We can ship via USPS Priority mail 6-10 day service for $9.95. Just place
the order normally, and mention "ship via USPS" and I will take care of it.
Dan
Now that I can live with!
Post by: frankenduck on February 06, 2012, 11:12:49 PM
Gaiters are constantly expanding/retracting as the forks move up and down while you ride.  If you're in a dusty/sandy environment with lots of sand/dirt in the air then it will get sucked in on expansion.  Not sure why that's hard to understand.
Post by: TaosBrick on February 06, 2012, 11:16:30 PM
Gaiters are constantly expanding/retracting as the forks move up and down while you ride.  If you're in a dusty/sandy environment with lots of sand/dirt in the air then it will get sucked in.  Not sure why that's hard to understand.
Yah, kinda like a squeezbox - not the kind that mama's got either ; )
Post by: DRxBMW on February 07, 2012, 12:08:43 PM
Charlie,
Dan
OK, I call and place a order this afternoon.
Thank you Taos for the legwork.
Post by: DRxBMW on February 07, 2012, 02:19:45 PM
Charlie,
Dan
Talked with Dan in person, my Traxxion protectors are in the mail.
Suggested they offer "shipping choices" on there website cart.
Post by: Lawrence on February 07, 2012, 02:52:51 PM
In the 48 years I've lived in an arid, semi-desert environment I have never found sand in any fork gaiters.  Seems like those are enough data points to convince me that I have other things over which to worry.
I guess BMW riders will be BMW riders, eh?   :lol:
Post by: DRxBMW on February 10, 2012, 04:25:18 PM
Charlie,
Dan
Traxxion protectors arrived in the mail this afternoon.
GIANT box, NO wonder they wanted to charge close to $19.00 for UPS shipping.
Why in the hell they required such a BIG box is a mystery to me. The actual product is small in size.
Anyway, I'll install them Saturday morning and report back. Plan is experiment with a height extension similar to the Touratech model guard.
Were supposed to get snow tonight according to the weather channel.  :dunno2:
GREAT ride this afternoon, GS is pathetically bathed in mud from head to toe. .  :bmwsmile :bmwsmile
Post by: DRxBMW on February 11, 2012, 08:24:46 AM
Installed the Traxxion guards on the GS.
JO, how snug are they supposed to be ?
There is some very slight movement but I think they will stay in place OK at speed.
In dual sport mode, read bumps & thumps, undecided.
I may have to break out the Dremel wonder tool and modify the inside edge so it will slip further down. Fork brace on the GS is more robust (thicker) than on our K machines.
Only bitch would be they need to be engineered in a left/right design. The right side Allen bolt is located on the inside, hence making the tightening procedure time consuming. Doable but there is a better mousetrap.
Camera charging, I'll snap some pics this afternoon.
Post by: johnny on February 13, 2012, 01:38:35 AM
i tighten mine down snug to the point where it would be a human struggle to move them by hand...
you gotts them on the fork sliders or the fork tubes... ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha
