TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Atabeach on November 19, 2026, 10:07:07 AM
1995 k75S ABS
The good: I got it to start, all lights work, the fan clicks on, shifts smoothly & brakes work. Alternator charges nicely. Propane test ( no change in rpm’s at 1.2k ) coils test 1.5 primary 10 secondary
The bad: Can’t get it to idle nice…Tank leaks, abs was tinkered with. Will remove soon
So far: fuel pump, new injectors , new temperature sender ( didn’t start till I changed it)
Balanced throttle bodies… balanced well at all rpms. ( 3 was out more than 1&2)
The bike will run ok with brass screws all 1&2 all the way in…not sure if that is relevant.
Z tube is cracked but I taped it off for the test.
I want to get her running properly BEFORE $$ and spline lube. TIA
