TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Aym on September 10, 2026, 02:54:45 PM
Title: K100 8V rebuild – timing after complete disassembly
Post by: Aym on September 10, 2026, 02:54:45 PM
Hi everyone,
I’m 20 years old from Canada and currently rebuilding the engine from my 1985 BMW K100 8V as part of a full café racer build.
This is my first time going this deep into an engine, and I made a mistake during disassembly. I removed the timing chain, camshafts and related components without marking their original positions.
The engine is now pretty much completely disassembled.
My question is: since I didn’t make any marks before taking everything apart, can I still correctly set the engine timing from scratch using the factory timing marks?
From what I understand, I need to put the crankshaft/pistons in the correct position, correctly position both camshafts, and then reinstall the timing chain. But I want to make sure I follow the correct procedure and don’t risk piston-to-valve contact.
I have the BMW repair manual, but I haven’t been able to find a clear step-by-step procedure for setting the timing when the engine has already been completely disassembled.
If anyone has done this on a K100 8V, I’d really appreciate some guidance. Pictures of the factory timing marks, manual pages, or a step-by-step explanation would be extremely helpful.
Thanks!
Title: Re: K100 8V rebuild – timing after complete disassembly
Post by: Laitch on September 10, 2026, 06:31:34 PM
Don't be distressed. In this case, provision has been made to align these components without marks having been made by the disassembler before taking the engine apart.
What I have found helpful is using different manuals for reference while I'm working. When I get stalled understanding one manual, I pore through the others looking for clarity. In your case, the Clymer manual has a clear answer to your question. The Haynes manual is also on the workbench.
(https://motobrick.com/gallery/4/1601-100926182532.png)
Installing the cylinder head and camshaft must be done carefully and patiently. Once installed with the cams positioned correctly, take a break because installing the timing chain and aligning the cam sprockets, gate rotor, and Hall sensor will need your undivided attention.
