TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: PrintTech on June 27, 2026, 12:56:03 PM
This is for a 1986 K100. Having dealt with the gunky fuel tank issue from fuel sitting for way too many years. Replaced the fuel pump, filter and lines. I also cleaned the fuel level parts, both for the gauge and the light. I get an open circuit when the float is up and about a 100 ohms when it is down. The issue is I never get a low fuel light. I pulled the bulb - it's good. I waited, as I read somewhere the circuit isn't instant to allow for fuel slosh. I finally pulled the connector and jumper it for a dead short as well. Still no light. I'm looking for some ideas!! Thank you!!
At the tank connector, when the float gets low enough the white wire is connected to the brown(ground) wire to turn on the dash indicator.
I've pulled and cleaned the float circuit in the tank. It had a lot of corrosion from ethanol fuel. I get good a good connection when the float lowers. I've replaced the tank connector as it was flaky at best. A part time fuel pump was a good indicator the connection was bad. I took the instrument cluster apart. I found no bulb in the spot for the low fuel light. I moved a bulb into that spot without luck. According to the service manual there is a fuel gauge circuit on the upper left side when facing the backside. I see no evidence this board was ever installed. I'm guessing it is for an actual fuel gauge since the sender unit can send both off/on and variable resistance information. Anyway, my meter shows I am getting a change of state when the float drops. It goes from an open circuit to one with continuity, still no light.
