TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Ingeneer M on April 21, 2026, 09:42:34 AM
Title: Strange tachometer reading
Post by: Ingeneer M on April 21, 2026, 09:42:34 AM
Hi, I'm new here. I am the proud son of an owner of a '85 K100RS. This bike has been sitting in the dust for more than 20 years and now I've decided to try to reanimate it.
I've disassembled everything and now I'm in the process of reassembling.
Just today I managed to fire it up for the first time!
But in the precess I've noticed a very strange thing on the tachometer. When I turn the key the tach stays at zero rpm, then, a few seconds after, it rises to about 2-3k rpm, without me ever cranking the ignition.
If I try to start the bike however the needle drops back to zero.
What could cause something like that?
Title: Re: Strange tachometer reading
Post by: Scott_ on April 21, 2026, 10:51:54 AM
Is everything else in the inst cluster working that you can tell?
There are multiple ground reference connections for the cluster, but the tachometer(and most of the cluster) uses pin 13 (brown), if it's connection to the frame ground reference is dirty it can cause strange issues with the cluster.
1st thing I would look at and check would be the cleanliness of all the frame ground connections.
After that, from the inst cluster on pin 16, is a black/blue wire that goes to the #1/4 coil. Make sure there hasn't been any rodent damage to the wiring.
It shares the ground/ECU connection at the coil. Check for corrosion, and good connection.
You say that the bike runs, so that tells me that the Ignition control is supplying an adequate ground for the coil to fire, which should also be good enough for the tach to read as well, provided the wire connection of the black/blue is clean enough.
