TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => Project Classic Motobricks => Topic started by: Hubert.szcz on December 19, 2025, 01:12:23 PM
Title: Trying to get a K75 up and running
Post by: Hubert.szcz on December 19, 2025, 01:12:23 PM
I've perused this site for years now, and finally making a post.
A family friend had an old K75 (VIN: WB1057401L0133114) he was going to get rid of because it hadn't run in a few years, I told him I'd take it and fix it up (this was late 2023). I replaced a lot of things and got it to run, rode it around the block. It still had a lot of issues, but I had to let it sit. I am only in the same place as the bike for a month or two a year. I got back in late 2024 and started working on the other things that needed doing before it was road-safe. The battery had died, but I knew I wouldn't finish the rest of the repairs until I had to leave so I didn't replace it, but got pretty much everything else good. Now it's late 2025 and I was really hopeful that with a new battery and a few odds and ends it would be ready to go, but alas, once again mysterious issues.
Every time I leave, I drain and dry the tank, disconnected the battery, and put a sheet over the bike. When I get back I add 1 gallon ethanol-free to the tank to see if it runs.
Here's the history of my repairs:
Nov-Dec 2023:
-   New used tank (old had a small leak)
-   New everything inside the tank (fuel pump, fuel sending unit, lines/hoses, fuel filter)
-   New (used) battery
-   New fuel out of tank line
-   New fuses
-   New injectors
-   New spark plugs
-   New air filter
-   Clean mass air flow and airbox
-   Clean top of engine block between airbox and plenum
-   New vacuum tube from fuel pressure regulator
-   Plugged California crank case evap intake
-   New throttle body vacuum caps
-       New Crankcase Breather Vent Hose
-   Stripped the allen-head bolts going into the fork stabilizer. Got a hardened steel extractor broken off into one, called it quits
<got it running and rode around the block at this point>
Nov/Dec 2024:
-       Battery died, did not replace.
-   Removed and cleaned out radiator
-   Replaced fan with new Spal fan
-   Got lower fork stabilizer off, replaced bolts
-   Replaced bolts for middle trifold
-   New front Spiegler steel front brake lines, bleed and new brake fluid (have matching rear brake line to put in later)
-   Bought new forks, (old forks deeply scratched and with a bolt stripped inside left fork)
-   New tires
-   Greased driveshaft splines!
-   Emptied final drive oil, but couldn’t get the filler bolt to turn!
-   Cleaned rear brake calipers with brake cleaner – pads don’t need replacing
-   Copperease on bolts: 4 wheel securing, 4 final drive securing
Dec 2025:
-   New battery (Odyssey PC680)
-   New starter relay
-   New Crankcase Breather Vent Hose... again ... was seeing cracking on new one already
-   Added coolant to radiator
Bare minimum still need to do (other than mysterious new issue):
-       Get the new forks in
-       Get the final drive filler bolt out, add oil, new bolt
So, now I beseech this community to help me get it to actually run. Turning the key gets all the lights to turn on, horn works. It cranks but won't start. Couldn't get it going with a push start. What's left to fix? Could my new fuel injectors have gotten messed up some how without any use in 2 years?
Title: Re: Trying to get a K75 up and running
Post by: John Lang on December 20, 2025, 08:41:59 AM
Does the headlight come on when you turn on the ignition? If not, there is a grounding problem: check the starter motor brushes.
Post by: John Lang on December 20, 2025, 08:46:27 AM
Oops. I see that it does crank so starter motor is fine.
Post by: Laitch on December 20, 2025, 10:13:33 AM
You’re learning useful lessons in this project from which others may benefit also! One is that buying replacement parts does not necessarily mean that a problem is being "fixed". Another lesson is: before replacing fluids in machinery, be certain the filler plug opens before opening the drain plug.
After some attempts at starting, remove the spark plugs and tell us whether they are wet with gasoline.
Post by: Edward on December 20, 2025, 06:31:27 PM
First on the list should have been locating and cleaning ALL the grounding points thoroughly. Use steel wool or very fine sandpaper. Please keep your battery on a quality trickle charger. If new, you need to initialize the battery first with a 24 hours pre charge. Make sure the battery has the correct specification. Do not underbuy quality. And yes, lets see the plugs. Hopefully you have the correct plugs. Personally, I use iridium on the K and my MV.
Post by: Hubert.szcz on December 30, 2025, 11:07:19 AM
Finally had some time to work on it. Plugs are dry. I detached the tube leading to the fuel rail, and unfortunately that is also dry when I try to turn it on - the pump isn't turning on. Next I'll check the various connections between the battery and pump with a voltmeter. The ignition coils give spark. I did notice when I pulled the plugs that the area inside looks a bit gunked up (see photo).
Post by: Laitch on December 30, 2025, 02:39:46 PM
Start by testing for voltage on both sides of the four-pin connector under the right side of the fuel tank when the ignition switch is On and the starter is spinning. Which wiring schematic are you using?
Post by: Laitch on December 30, 2025, 05:36:39 PM
While you're resting, probe that gunk in the spark plug holes and let us know the depth of the debris in there and whether it is sludge, granular or solid.
Post by: Edward on January 02, 2026, 12:09:02 AM
Given the visuals of possible gunk... Looking forward to more detailed photos.
You had stated the injectors are new as 2023, nonetheless it would be wise to use a 9 volt battery to test the spray.
Post by: Smudgemo on January 02, 2026, 03:07:01 PM
Is the fuel pump actually not working?  Make sure the fuel lines from the pump and filter in the tank are still attached as they should be.  I had the hose between the filter and the tank's hard line pop off not long after I replaced everything.  Not pushed on far enough or insufficient clamping force, I suppose.
When it happened, the bike didn't immediately die, but didn't run right or very far.  Residual fuel probably still working its way through the system.
Post by: Hubert.szcz on January 04, 2026, 04:04:32 AM
Battery is at ~13V
Right two holes give 11.07V when key is turned, 9.8V with starter spinning
left two: 1.4V when key is turned, -1V with starter spinning
Opened up the tank again, all the tubes are secure (to/from the pump, filter, and out of the tank). None of the fuses are burnt out. Where is my missing voltage hiding? Should I replace the connector?
Not sure what you mean by wiring schematic.
I didn't get a chance to look into the gunk again, leaving for a trip. Will pick this up again in February.
Post by: Laitch on January 04, 2026, 12:18:51 PM
What are you trying to determine by probing contacts on that particular connector?
Post by: Hubert.szcz on March 21, 2026, 04:27:52 PM
Back to hit my head against this wall again :mb:
@Laitch I thought that was the connector you asked me to test?
I also found this connector leading to the electronic control unit from the hall sensor which crumbled at one point, I also noticed that the colors of the wires on one side don't match up with the colors on the other side. Can I just replace the plug?
Since the tank is off, empty, and dry, I'll also try to hook up the battery directly to the fuel pump to see if the pump is still good.
Post by: Laitch on March 21, 2026, 05:05:48 PM
I asked you to test a 4-pin connector; that's a five-pin connector. How many wires are connected to that plug and what colors are they?
I was attempting to get you to check both sides of the connector that joins the fuel pump/fuel injection relay to the fuel pump and fuel sender. The original plug should look like this unless somebody has replaced it.
(https://motobrick.com/gallery/4/1601-210326170311.png)
Post by: Hubert.szcz on March 21, 2026, 06:13:18 PM
I also took out the pump to test it. Nothing happened at first when I connected it to the battery directly, but after a few touches with the wire it eventually got humming, so maybe there was a small seize in there. The pump and all associated parts are new, rubber is good, white mesh thing at the bottom is pristine, it just sat dry for a few years. As I was putting it back in one of the wires broke, so maybe that was also a weak point.
wire colors:
White circular plug in relay box: green/blue, green/brown, brown, red/orange
plug connecting fuel pump I tested initially: white, brown, yellow, green/white
Post by: Laitch on March 21, 2026, 08:33:48 PM
Those are the correct colors for incoming fuel injection relay wires to the fuel pump and sender plug. So you initially tested the correct plug being used for that purpose. Forget about the white plug for now.
In your first test, instead of telling us which hole had which value, tell us which color wire connected to each hole had which value.
Are you working with a wiring schematic?
Post by: Hubert.szcz on March 21, 2026, 09:47:23 PM
Battery at 12.6V
Yellow+white green: 3.8 with key turned,  -3.0 with starter spinning
Brown+white: 11.22 with key turned, 10.20 with starter spinning
I'm guessing from your comment that I should be working with a wiring schematic? I found some, but not sure how to use it to determine which pairs of wires need which voltages.
Post by: Laitch on March 21, 2026, 10:47:06 PM
Only a basic understanding of engine electrics will help develop the ability to determine the amount of voltage a process or component needs to operate optimally. YouTube has plenty of resources that can help. The LE Jetronic manuals downloadable from this site can help. The troubleshooting guide downloadable from the service manuals section can help.
In the present circumstance, a 12V fuel pump needs 12V to operate optimally. It can run on 10V but it should get closer to the full load. Even if there is 12V available, a faulty connection can deprive the pump from having enough voltage to run well, or at all, as you have learned. When voltage is checked on the input plug of a connection, it must also be checked on the output plug of the connection to determine if the wires connected to the output plug are receiving the input; however, you must know the purpose of each wire; that is what the schematic will show you.
It is likely others here will be chiming in shortly.  112350
Post by: Edward on March 21, 2026, 11:26:11 PM
That fuel connecter is shit, I'd replace it with a superseal. At least get in there and scrape off the corrosion off the female side and clean off the pins on the male side. Every connector you take apart should be carefully inspected and all connecting wires. Thats base for elderly harnesses. Give this a view: https://www.youtube.com/watch?v=ZjU28ozQTvc
Post by: Hubert.szcz on March 28, 2026, 12:48:35 AM
Update:
First I cleaned the three grounds I could find (two near the battery, one at the center of the frame), and all things that touched them. I then removed all the fuses and sprayed electrical cleaner through those connections (all fuses are new). I also checkout out the fuel sender relay, looks clean, pretty sure it's new.
Then I rechecked the voltage in a variety of places:
Battery (key not turned): 13V
Battery (key turned, lights on): 12.6V
Battery (ignition pressed, starter going): 11.6V
starter relay: same voltage as battery
Fuel sender plug (key turned, lights on): 11.1V
Fuel sender plug (ignition pressed, starter going): 10V
Fuel sender relay (key turned, lights on): 12.3V
Fuel sender relay (ignition pressed, starter going) 0V
Fuse #6 (second from bottom, key turned): 0V
Fuse #6 (ignition pressed, starter going): 0V      [I guess I must have done this wrong?? I took the fuse out and put the voltmeter probes in both slots]
I also found a flat plug that doesn't attach to anything (in photo) - not sure if it should.
And, importantly, when key is turned and lights are on, if I bend and press the main coil of wires in a particular way (more or less where I'm pointing in last photo), the headlight dims or goes out.
Does this mean I have a cracked and shorting wire somewhere in the harness? I'm guessing next step is to try to pull the harness out, or at least make it more accessible, unwrap it, and look through the wires?
Post by: Edward on March 29, 2026, 01:43:09 AM
I'd unwrap the junctions first, where the wires join as a leg of the main harness vein. See if you can spot any decay. Wires tend to be fine in straight runs. When you press on the group of wires, carefully notice how the force is applied to which wires or groups of wires. Do this carefully as you see the light dim to try to trace closer to the source. Be a detective. —Be sure to have your battery tendered as this process can be a drain.
