TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: schrocketeer on September 10, 2025, 01:43:28 PM
Title: Intake boot clamp source?
Post by: schrocketeer on September 10, 2025, 01:43:28 PM
May I please have source recommendations to secure the rubber boots between the airbox and throttle bodies?
I'd rather not go back with the OEM Oerliker clamps, since they seem to be one-time use.
As I measured last night, the worm clamps need to be 7mm wide, and 42mm for one side, and 50mm for the other.
Didn't check carefully enough when I ordered these, since they're 12mm wide: https://www.amazon.com/dp/B0CJV9BBJ7?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
FYI, zip-ties/tie-clamps can leak, and look like lots of other problems, sending you on a wild goose chase. Ask me how I know. :-\
Title: Re: Intake boot clamp source?
Post by: schrocketeer on September 10, 2025, 04:03:51 PM
https://www.mcmaster.com/54195K32/ looks to be a good candidate.
Post by: Kaos on September 10, 2025, 05:26:35 PM
T-bolt hose clamps, stainless. Also aestheticly more appealing.
Or Google for intake manifold clamps and the wanted mm's
Post by: frankenduck on September 10, 2025, 08:55:35 PM
If you put the worm drives on the back you get a very clean look.
(https://ckb.kbikeparts.com/ckb.tech/0.ckb.tech.files/k75pa.rehab/k75pa.ab.tb.comment/k75pa.ab.tb.85.k75pa.uppertbbootsclamps.JPG)
(https://ckb.kbikeparts.com/ckb.tech/0.ckb.tech.files/k75pa.rehab/k75pa.ab.tb.comment/k75pa.new.tb.hose.clamps.jpg)
Post by: lewisnort on September 11, 2025, 05:11:53 AM
SKU FUA60940-2 from motorworks are what I used thought that can get a bit pricey and most certainly cheaper from somewhere else since they're just generic clamps.
Post by: schrocketeer on September 12, 2025, 04:26:42 PM
The clamps from McMaster-Carr came today, 10 pack was $20.01. I have two Bricks that need new clamps, so got 2-10 packs. With shipping it was $54 in the US.
Pictures show the box they came in, if you want to source separately. Also attempted to show the fit in the upper and lower boot slots.
Descriptor
https://www.mcmaster.com/catalog/131/330/54195K32
Worm-Drive Clamps for Firm Hose and Tube
305 Stainless Steel Screw, 5/16" Band Width, 1-11/16"-2-1/4" Clamp ID
54195K32
Post by: rbm on September 14, 2025, 05:19:14 AM
48mm Suzuki band clamp part number 09402-48208 for TB->bushings and bushings->air plenum connections
.  perfect fit.
