TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: mrt6644 on September 05, 2025, 05:57:10 PM
Title: Diagnose fan/temp relay
Post by: mrt6644 on September 05, 2025, 05:57:10 PM
Hello.  Ive been through countless threads and can't seem to get this straight.
I have a 95 K75 and I want to get the fan working as it is supposed to when new.
I replaced the fan so I know it's working.
I am using the oem relay and wiring.
What is going on is that the fan turns on right when the engine starts and stays that way.
I am trying to figure out how the relay is supposed to work.
I know that power goes to pin 15, ground to 31.
I know what A2 and A3 are for.
What I don't get is the triggering.  Originally I thought the the fan relay was triggered by low resistance to pin E.
However, it seems that the relay only triggers with 12+ volts to pin 9.
Which doesn't make sense as power on Pin 9 is always on right?
Ive tried applying ground to E, nothing.
What am I getting wrong?
Title: Re: Diagnose fan/temp relay
Post by: frankenduck on September 05, 2025, 07:19:34 PM
When E resistance to ground goes down into the 150-200 ohm range the temp relay shorts 15 to A2 to power the fan. 9 powers the temp relay.
Post by: mrt6644 on September 05, 2025, 07:58:52 PM
I was testing by putting e to ground and no dice.  Is ground too
Low resistance for this?
I was testing the relay with a power supply and I might have fried it
Post by: Laitch on September 05, 2025, 10:29:18 PM
From your description of the Brick, it could have been damaged before it came to you or it just could have failed from old age. Beemer Boneyard has a used one and there a couple of used ones on eBay.
Post by: mrt6644 on September 05, 2025, 10:33:27 PM
Yeah, I was thinking g the relay is damaged and I damaged it worse.
If the resistance to E is brought down close to 1 ohm or a direct connection, does that still trigger the fan?
Post by: frankenduck on September 05, 2025, 11:09:31 PM
If E resistance gets really low or grounds then it should trigger both the fan and the overheat light in the luster.
Post by: mrt6644 on September 05, 2025, 11:12:31 PM
So then the relay was probably damaged. I ordered a used one from Beemer boneyard
Thanks
