MOTOBRICK.COM => The MBdotCOM Community Center => Topic started by: Bill Fulton on September 01, 2025, 11:21:12 AM
Title: Windshield cleaning mistake -> help?
Post by: Bill Fulton on September 01, 2025, 11:21:12 AM
Thought it would be nice to polish the windscreen on my '93 K75S. I started with Novus mild scratch remover.
Big Mistake. I now have marks on the screen. Marks from the polish, in the rubbing pattern.
Now what?  Is there a nice mild (or not) way to remove this?
Title: Re: Windshield cleaning mistake -> help?
Post by: frankenduck on September 01, 2025, 10:58:28 PM
https://www.kbikeparts.com/classickbikes.com/ckb.tech/0.ckb.tech.files/paintitblack/paintitblack.htm
Post by: daveson on September 03, 2025, 12:43:41 AM
A few more options. Your screen might have a protective film, in that case it's probably damaged and wants to be removed.
Not sure if your screen is aftermarket. Not sure if it's polycarb or acrylic. You can polish acrylic, if you try to polish polycarb you just end up with thousands of scratches. This is one way to tell the difference (usually in a small inconspicuous area) which you may have just found out the hard way, so I'll guess for now that you have a polycarb screen.
You can remove scratches from polycarb with a propane gun. It's hard to describe and if it's a first attempt, you want to use a spare piece for practice. Work in a circular pattern and looking at the screen at a reflective angle, as soon as it gets glossy, move the gun to a new position. Hold the gun further from the screen than it needs to be, say six inches, and slowly bring it closer until you find the sweet spot, leaving it too long in one spot will cause it to turn white, which can also be fixed, but you want fewer headaches, not more.
For sure there will be YouTube videos with a much better description than mine.
Post by: Bill Fulton on September 05, 2025, 06:30:59 PM
I used Griot's Garage plastic "all in one" polish. Worked like a charm. It's clear and shiny.
Great stuff, as it turns out.
Post by: Laitch on September 05, 2025, 07:18:06 PM
Thanks for the followup, Bill. icon_cheers
Post by: Bmwsquirl on September 10, 2025, 12:15:06 PM
I dont know about scratch removal but........3m windshield cleaner at Napa about 3 bucks a spray can black can red writing.a Harley owners manual in the 90s said to clean wind screen in one direction once you use that direction never change.(up and down)(side to side) never circular.this way the scratches will not effect vision thru screen as there all the same direction.been doing it over 30 years and no scratches.and yes I tried a polish and it scratched the hell out of it could never get them out.live and learn.
be safe
squirrel
Post by: Bmwsquirl on October 10, 2025, 02:37:29 PM
update, went to buy a can of 3m at Napa they stopped making it.all three guys ride and know I use it one of them tells me the story another goes to the backroom and gets me a can of crc foam cleaner.worked just as good as 3m stuff.told me they dont put it on shelf out front its a secret handshake thing
be safe
squirrel
Post by: The Mighty Gryphon on October 10, 2025, 10:10:42 PM
Are you allowed to tell us what you got?  Do we need the secret handshake?
CRC makes about a dozen foam cleaners.
Post by: Bmwsquirl on October 11, 2025, 04:30:41 PM
g man
its
crc
glass cleaner
professional grade
foaming ammonia power
that's the front of the can
be safe
squirrel
Post by: The Mighty Gryphon on October 12, 2025, 06:46:53 AM
Thanks!
