TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: NMPete on July 20, 2025, 06:42:51 PM
Title: K75 Flooding
Post by: NMPete on July 20, 2025, 06:42:51 PM
Hi -  Well, I’m still stuck. I finally got my 1988 K75 C (16K miles) started (replaced the injectors) but it is still flooding after a difficult start.
If I unplug the fuel pump it will start and idle until it runs out of fuel.  If I plug in the fuel pump, it immediately floods, but will start with full open throttle.  It jumps to 5K RPM and has a lot of exhaust smoke. If I let it warm up (at 5K) and rev it to 6K, it revs up quickly and easily to 7.5K sounding normal (good). If I drop below 5K it immediately stalls (floods out because the plugs are soaking wet with gas). I did a lot of reading in the Forum and found one person with a similar problem, but there was no solution.
I have been trying to resolve this for several weeks with no luck.
Here is what has been done:
- New fuel injectors
- Used ECU (has exactly the same response as the original)
- Installed a used cleaned and tested water temp sender
- New spark plugs that have strong spark at starter cranking and at 7K
- Tested the air flow meter, air temp sensor and fuel pressure (36 PSI static and 34 PSI steady at 6K-7K  RPM) per the wonderful Troubleshooting Guide
I have no BMW mechanic in less than 200 miles and they only like newer bikes.
So, after repeated testing and changes, I can’t get it to run like normal. I have a feeling this is a good bike mechanically and want to get it running correctly. If you know anyone that can help, please let me know.
Any suggestions?
Many thanks
Pete
New Mexico, USA
Title: Re: K75 Flooding
Post by: frankenduck on July 20, 2025, 07:15:28 PM
What new fuel injectors did you install?
Post by: daveson on July 21, 2025, 04:53:08 AM
I had a problem which I think matches your symptoms. The injectors are supposed to be getting constant power and a pulsing earth. If they're getting constant power and constant earth, the injectors will remain on instead of pulsing on and off, causing flooding.
Using a screwdriver like a stethoscope against the injectors, you should be able to hear the injectors ticking while cranking. If they're not ticking, that's a problem.
Post by: NMPete on July 21, 2025, 10:42:41 AM
I bought new injectors form Euro Electrics in Denver CO.  I also had the  original injectors cleaned at InjectorRX in Houston TX.  They did a great job for good price.  Tried both sets - always the same flooding.
I'll try the screwdriver trick.
Thanks
Post by: stokester on July 21, 2025, 06:41:44 PM
I'm not sure of the exact symptoms of a failed fuel pressure regulator but did you check the pressure to the fuel rail?
I agree that checking the injector signal would be next on my list.
Post by: NMPete on July 22, 2025, 11:36:41 AM
I did try the "screwdriver trick" and yes, I could hear each of the fuel injectors clicking regularly with starter running and the fuel pump disconnected (sounded like Norton valve tappets!).
The fuel pressure regulator seems to be working correctly; 36 PSI at idle and 34 PSI at 7000 RPM.
Any idea of a different sensor that would cause flooding?
Thanks
Post by: The Mighty Gryphon on July 22, 2025, 12:52:07 PM
On the end of the throttle bodies is a module called the throttle position switch (TPS) with two micro switches that sense the position of the throttle butterflies.  Have you tried unplugging the module?
If the components in the system are working properly, then the problem may be in the engine control wiring harness.  You may have worn insulation allowing a short circuit to ground or a broken wire.  Have you checked the signal values from the engine sensors at the big connector at the ECU?
Post by: NMPete on July 22, 2025, 01:39:49 PM
Yes, I tried with the TPS unplugged - no change.  I did the Ohm and 12V tests on the ECU plug as described in the Troubleshooting Guide.  Everything seemed O.K. per the expected values.
The water temp sensor is good, but not sure if connection is good.  Is there a way to test it?
Thanks
Pete
Post by: The Mighty Gryphon on July 22, 2025, 01:51:35 PM
Pins 10 and 13 of the big ECU connector are connected to the engine temperature sensor.  2500 ohms at room temperature and about 250 at operating temperature.
Post by: Laitch on July 23, 2025, 12:36:16 AM
The fuel injection timing is primarily based on engine speed. The Hall Effect Sensor (HES) supplies the engine speed signal. The engine speed signal is the basis for cold starting and running with inputs from the air temperature signal, intake air volume signal, coolant temperature signal and the throttle position signal. The HES hasn't been checked. If the HES is sending a signal indicating an engine is running at high revs when in fact it isn’t, it’ll be flooding until it is actually running at high revs, which seems to be what is being described here.
The ignition control unit outputs the engine starting speed at pin#8. Its output should be checked. An extract from the troubleshooting guide is below. They are measured as AC values not DC.
(https://motobrick.com/gallery/4/1601-230725005850.png)
Post by: daveson on July 23, 2025, 03:34:19 AM
Did you use Teflon tape on the temperature sensor?
Post by: frankenduck on July 23, 2025, 04:06:19 AM
(https://www.meme-arsenal.com/memes/fd5efe8e8ef3b3d9b03c598673896237.jpg)
The HES sensors only send a signal when the hole in the rotor cup passes by them.
(https://i.ebayimg.com/images/g/LZcAAOSwWk9hDWBk/s-l1600.webp)
Post by: daveson on July 23, 2025, 05:34:05 AM
Yeah, if the sensors are working properly, but they might not be. At say 4,000 rpm it's working at rapid speed, but if it gets lazy it might take one second or more to turn off, then it probably won't be turning off or on.
Post by: Laitch on July 23, 2025, 10:20:01 AM
Firsly, it's dangerous to put self-portraits in your posts on the Web. You should remove that before somebody on the Dark Web misuses it and takes advantage of you.
 :laughing4-giggles:
Secondly, I understand from your bio that you know all that you do from making more mistakes working on Bricks than almost anybody. I haven't gone that route. All I can claim is that I don't know what short circuits, crossed wires and etc. within the HES wiring harness can do, and also that we're discussing a K75—not a K100—the rotor of which has two windows yet is designed to send three signals.
If Pete will check the output at ICU pin #8, that could reveal something. Certainly if, as he claims, everything he already has checked is perfect, the failing of perfection is quite an anomaly.
(https://motobrick.com/gallery/4/1601-230725105512.png)
Post by: NMPete on July 23, 2025, 06:50:01 PM
Hi - Sorry for the delay; my internet was our for 1/2 a day.
I did test the water temp sensor at ECU #10 - got 2250 Ohms.  Also, tested sensor housing to ground - 0 Ohms (cleaned male and female threads and no teflon tape).
Tried to test the HES at pin #8 of the plug; got 10.8VAC when I push the starter button.  All I have is a cheaper VOM from ACE Hardware and not sure I can measure mVAC with this.  Of course the starter is not working with the HES unplugged.  To test this with the starter running (or the bike running) I guess I would have to strip the correct wire a little?
PS:  I looked at the Hall sensors, look clean and no oil or overheated wires, etc.
Post by: daveson on July 23, 2025, 07:23:23 PM
The coils should be receiving a pulsing earth signal at pin one, from the hall sensors. Not sure about the location of pin one on a K75, but here is the test on a K100, with an LED test light, clamped to battery positive.
https://youtube.com/shorts/5VrtFtr07-4?si=XDsprvcOJm3lh-Yx
Post by: Laitch on July 23, 2025, 08:02:56 PM
Don't be stripping wires. Don't base electronic component function capability by the looks of its wiring. The process of elimination will get you back to the HES and ICU if necessary.
Post by: frankenduck on July 23, 2025, 08:28:28 PM
 :laughing4-giggles:
Yes, 3 and 4 cylinder HES are slightly different but the rotor cup will never spin six times as fast as it should which is what you imply. Also, if the HES could (which it can't) send out six times as many pulses as it should than the ICU would fire the plugs six times per revolution. Good luck with that.
As I stated: UNPOSSIBLE.
Post by: Laitch on July 23, 2025, 10:03:12 PM
You're inferring that. I'm not implying that. I discussed the difference because you weren't making it clear in your illustration. I'm stating the ICU output and the HES input need to be investigated when feasible. In this case, they'll probably considered if other areas of exploration are cleared.
Post by: daveson on July 25, 2025, 09:20:54 AM
[quote ...fuel pressure (36 PSI static and 34 PSI steady at 6K-7K  RPM) per the wonderful Troubleshooting Guide...
[/quote]
I'm wondering if we can be confident about the fuel pressure gauge, seems strange that the pressure drops at higher revs.
It floods and dies when the tank is connected. I'm thinking about the possibility that the return valve in the tank is blocked, causing flooding, this has been an issue with a few threads. If you extend the fuel return line into the tank through the opening for the filler cap instead of the return valve, that might solve the flooding problem. If it does, the return valve is probably blocked with rust and crap, then just carefully clean it out. Another test would be to direct the return hose into a fuel container instead of it being connected to the return valve under the tank.
It's on the cards if it's been in storage for say a few years.
Post by: NMPete on July 25, 2025, 11:32:22 AM
Hi -  I didn't know there is a return valve in the tank.  The pressure regulator seems to be working O.K.  My fuel pressure gauge is new and I think it is good, but it could be off some.  I will test it again.
I will try the return line into the filler opening.
Thanks
Pete
Post by: Laitch on July 25, 2025, 02:17:01 PM
. . . the possibility that the return valve in the tank is blocked, causing flooding, this has been an issue with a few threads. If you extend the fuel return line into the tank through the opening for the filler cap instead of the return valve, that might solve the flooding problem.
If Pete's fuel tank is its original, it doesn't have a return valve; it has a standpipe within the tank. That change was made in 1986, according to Largiader at Virgina Motorrad. Models eventually had the standpipe's outlet empty at the ceiling of the fuel tank just above the vapor evacuation chamber. This was done so fuel wouldn't spill from the return hose port when the hose was detached.
Post by: daveson on July 25, 2025, 02:38:30 PM
Yep that rings a bell, funny though since you'd think the valve would prevent that anyway. Maybe it's blocked anyway, or maybe the hose or the pressure regulator itself.
It seems that everything is good, but something must be wrong to cause flooding. One easy check would be to remove the filler cap assembly and look to see if fuel is returning to the tank while cranking (it might be easy to see without removing the assembly) If there's no fuel return, that's a definite problem which would result in higher fuel pressure, causing flooding. There's something strange about the pressure being lower at revs than at idle.
Pete, where was the pressure gauge attached?
Post by: NMPete on July 25, 2025, 05:43:59 PM
Great questions - The gas tank is not original; it is a little bit later but the same fit, etc.  The filler cap is removed. With the pump on (starter button and when running at 5K +) there is fuel returning from a series of metal tubes along the top of the inside of the tank from the return hose outside.  I have tested the "inlet" pressure (hose from the tank) and the "return" hose  - both show 36 PSI.
I will do a pressure test again next week and monitor it at different RPM ranges  and let you know.
Thanks
Pete
Post by: Laitch on July 25, 2025, 06:12:32 PM
Agree with daveson. Return pressure shouldn't be that high; it should be a trickle to light stream. Your gauge is faulty or maybe the fuel pressure regulator is faulty.
Post by: daveson on July 25, 2025, 07:30:34 PM
Doh, I was editing this post, not realising there was a reply on the next page, so I deleted it and copied it downstream:
Fuel should also be returning to the tank when it's cranking. If fuel isn't retuning while cranking, that would explain why the pressure is lower at revs.
One of the other basics when you're in the tank, is to see if the fuel filter is installed the correct way around, and that it's not blocked.
Was the reading on the return hose, upstream or downstream of the regulator? Because downstream of the regulator the pressure should be about nix pounds per square inch. The fuel retuning to the tank should be dribbling down, not spraying in
Post by: haristocrat on July 25, 2025, 09:33:17 PM
Pete
By ‘“return” hose’ do you mean the hose curling back around from the fuel rail to the fuel pressure regulator OR do you mean the hose from the FPR back to the tank? If you mean the former, then 36 psi sounds correct as the pressure should be the same everywhere upstream of the FPR, and the FPR is probably functioning correctly.
I disagree with Daveson on the FPR behaviour. It does in fact make sense that the fuel pressure (relative to ambient atmosepheric pressure) drops at high revs as compared to idle. The reason for this is that there is a vacuum hose between the throttle body and the fuel pressure regulator diaphragm that supplies the FPR with the actual (negative) pressure that is present at the point of injection. This allows the FPR to compensate in real time for the greater vacuum present when the engine revs up. This keeps the pressure differential at the injector relative to the intake air stream constant. Higher revs means lower intake air pressure hence the fuel pressure is decreased to maintain the same injector duration parameters.
Post by: daveson on July 25, 2025, 10:08:14 PM
Yes I see your point, but at high revs the vacuum could be high or low, depending on the situation. I haven't done any tests to verify my point, but according to the LE Jetronic diagnosis manual, the pressure should be under 30 psi at idle,  and 32 to 36 psi at 3,000 rpm.
I agree with your distinction about the return hose pressure being lower after the regulator, than before it.
Post by: Laitch on July 25, 2025, 10:19:12 PM
The only fuel "return line" is attached to the top of the regulator and connects to the fuel tank return port.
Post by: haristocrat on July 25, 2025, 10:27:46 PM
Agree with you. I don’t know the exact behavior but based on your quote it sounds like under steady state the high RPM throttle pressure is higher than idle.
 I guess my point was that the throttle vacuum relative to idle may decrease the fuel pressure under some conditions (e.g rolling off throttle at high revs) so it’s not necessarily a fault condition.
Post by: Soggz on July 26, 2025, 01:19:53 AM
I had this. A new temp sensor fixed it. Also, I sent the injectors off for testing. They came back ok.
Post by: NMPete on July 27, 2025, 03:04:30 PM
Hi  -  Maybe that is my problem: I thought the return pressure should be 36 PSI.  From the Troubleshooting Guide:
"Fuel pressure is sent from the pump to the Fuel injector rail. The fuel pressure
regulator will keep a constant pressure into the fuel injector rail[/u]. The fuel pressure
regulator is located on the back of the fuel injection rail (not easy to access) and its
depression is collected at the intake manifold for cylinder #4. The fuel pump is
delivering 65 PSI of pressure, and the pressure regulator drops it to 36PSI."
I assumed the pressure regulator was working correctly.
Should the return pressure be less than 36 PSI?
Thanks
Pete
Post by: NMPete on July 27, 2025, 03:07:29 PM
Soggs - Which temp sensor did you replace (water or air)?
Post by: Laitch on July 27, 2025, 03:22:35 PM
The line from the rail to the pressure regulator is used to control and adjust fuel pressure and fuel delivery from the pump; it is not the return line. The return line is attached to the port at the top of the regulator and then to a port in the floor of the tank. Return flow should be a thin stream at the outlet within the tank (10psi to 0psi). If the return line were clogged, psi from the tank to the rail would spike well above 36 psi.
Post by: daveson on July 27, 2025, 06:43:17 PM
Yes.
As Laitch says, the fuel pressure (downstream of the regulator) should be close to nothing.
If it's 36, that's a problem. that would mean there's a blockage downstream of where you connected the gauge, either the hose or the tank. It should be easy to blow air through it.
If the blockage results in 36 psi, that's an unfortunate coincidence, that should not result in flooding.
That guide is a really good one, but there are a few small mistakes in it, you've just found one. The regulator doesn't reduce the fuel pressure, it increases it from close to nothing to 36 psi. If there's a total blockage for example in the return line, the pressure would build until something failed, for example a hose might burst. To prevent damage, the pump has a pressure relief valve, it opens at about 60 psi.
Is fuel also returning to the tank while cranking?
Post by: Laitch on July 27, 2025, 07:58:57 PM
I've edited my previous post (post #33) which was a product of sleep deprivation and general impaired consciousness.  177381 Maybe it will make more sense now.
Post by: The Mighty Gryphon on July 27, 2025, 09:03:35 PM
To continue the merciless flogging of this deceased horse and distilling the knowledge dispensed above..
The pressure at both ends of the fuel rail should be the same and approximately 36psi or 2.5bar.  At the return spigot on the fuel tank it should only be enough to open the check valve which should be very close to 0psi.
More than 10psi at the return connection on the tank probably indicates a tank problem.
High pressure on the rail but low at the tank indicates a problem with the pressure regulator.  Low pressure on the rail could be caused by a bad regulator, weak pump or a plugged fuel filter.
Post by: daveson on July 28, 2025, 03:21:45 AM
I've edited my previous pos (post #33) which was a product of sleep deprivation...
Good morning Laitch. Did you post an acronym? I think so not. You didn't, didn't you? I've only had one coffee yet but.
Post by: Laitch on July 28, 2025, 09:33:39 AM
IDKIIDON
 :idunno:
Post by: NMPete on July 28, 2025, 08:03:06 PM
Hi  -  Hooked up my fuel gauge again and I get 35 PSI from the tank to the injector rail.  Gas is returning to the tank O.K.
So  - This Is amazing -  It started while testing fuel pressure and lo and behold it stayed running!!!!!!  Warmed it up and it revs to 7K smoothly - sounds like a nice bike!
Not sure what changed to stop the flooding, but think it might be a connector to the Fuel Injection Module.  I unplugged and replugged several time so maybe that was it.
See my new post.
Thanks
Pete
Title: Re: K75 Flooding - Part II
Post by: NMPete on July 28, 2025, 08:15:15 PM
Hi  -  Hallelujah!  I finally got it running and it sounds great.  Revs smoothly from idle to 7K.  Must have been a bad connection because all I finally did was clean up connectors so not sure what the flooding problem was. Now I feel it is worthy of a nice renovation.
I want to say a special thanks to everyone that took time to give advice - it was a great help!
Pete
Post by: natalena on July 28, 2025, 08:47:26 PM
Great to hear your brick is running. Cleaning up connections and grounds is always a sound idea. Cheers
Post by: daveson on July 28, 2025, 10:09:30 PM
...Ok, Thanks for the update. Threads where the problem is fixed are the best threads.
