TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Los_gatos on July 06, 2025, 01:00:48 AM
Title: Rate my splines?
Post by: Los_gatos on July 06, 2025, 01:00:48 AM
Hi I was going to see if anyone could rate my splines. New to me 92 k75 63k miles. Looks like the original owner took good care of it. The guy I bought it from, not so much. I'm excited because I know final drive splines are kinda the death knell and couldn't inspect them before I plunked down money. Thanks.
Title: Re: Rate my splines?
Post by: Los_gatos on July 06, 2025, 01:02:54 AM
Here's the female splines.
Post by: frankenduck on July 06, 2025, 01:31:51 AM
8.3
Pretty good for 63k and you'll easily get another 50k and more if you keep them lubed.
Post by: Los_gatos on July 06, 2025, 01:37:17 AM
Awesome. Thanks! I bought some TS-60 spline lube for it.
Post by: frankenduck on July 06, 2025, 02:22:46 AM
Smart move. TS-60 the FD splines at every rear tire change and life will be good. It's probably overkill but much cheaper than replacing the drive shaft and FD. I have Scottish blood so I like to err on the side of cheapness.
Post by: Laitch on July 06, 2025, 09:09:03 AM
Clean the shaft splines thoroughly before the application. Molybdenum bonds to surface metal; applying it over dirty splines lessens the effect of a new application.
Post by: Los_gatos on July 06, 2025, 12:41:01 PM
Should I use chemical (brake clean)? I took a pick tool to the splines per Chris Harris. Thanks.
Post by: Laitch on July 06, 2025, 02:20:17 PM
You're on the right path. Lacquer thinner, mineral spirits, brake cleaner or soap and water then wipe down with a rag.
