TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: effjay on May 06, 2025, 04:07:21 AM
Hi everyone,
this topic has been addressed here several times. To the best of my knowledge I have gone through many of the suggestions. I find myself however, at a dead end of my knowledge and that's why I ask for your support and guidance.
My K1 has always started. Always garaged. It has 43000 km. After this winters pause it needed a new battery (although it spent all winter on a BMW trickle charger!).
I installed a new battery and the bike started immediately. I then rode a little bit until she was warm and put her back in the garage.
A week later I turned the key and the pump doesn't prime.
Up until now I have done these things...
This is how I have tried to start the bike:
- Gear in neutral (light on dash is green)
- Killswitch on handlebars is in correct position.
- Clutch pulled.
- Side stand up.
- Fuel gauge is working.
- The starter motor spins.
- The battery is healthy.
- The fuel pump just doesn't excite.
This is what I have checked to try and rectify the problem:
- Checked all fuses for continuity - all OK.
- Each of the fuses have 12v coming in.
- Bridged the side stand switch/connector to see if the fuel pump will excite. No.
- Sprayed the side stand switch and cable connector with contact spray.
- Tested Motronic Relay - OK
- Tested fuel pump relay - OK
- Tested Motronic & fuel pump relay seat (pole 30) for 12v - OK
- Maybe there's a Motronic (engine control unit) error?
(I have unplugged it and plugged it in again more than once).
I'm stuck and would love to hear you opinions about the next steps I should be taking.
Many thanks to you all in advance!
Is there 12 volts at the fuel tank connector when the key is turned on? You should see 12 volts for a second or two when the key is turned. Depending on whether or not you see that voltage will tell you where to look for a problem.
***UPDATE***
Removed and tested the fuel pump.
Does it work? Of course it doesn't.
Measured voltage on pump wiring - 12v delivered.
New parts on the way - actually good that we looked, the fuel pump damper was falling apart - one big sticky mess.
will report back when the parts have been installed - hopefully with good news!
Yes. 12v available at the fuel pump. 👍🏻
My update reports on the latest discoveries.
