MOTOBRICK MARKETPLACE => NM ~ Not Mine - Just Compeled To Post It Up => Topic started by: beemuker on January 14, 2025, 09:18:31 AM
Saw this over on MOA. How available are the 12 rivet output shafts used? Looked on eBay but only saw 6 rivet.. anyone got a spare shaft lying around? I like my R1100 but I miss having a brick.
https://marketplace.bmwmoa.org/classified/1985-k100-project-bike-listing-33962.aspx
I've got a used driveshaft but the splines are shot. I don't know if anyone does any re-welding of splined driveshaft ends. If it helps, I have a matching final drive with disk brakes / ABS ring. I'm sure you would find something more suitable!
Good luck!
You have to mail the drive shaft to Holland to get the splines replaced:
https://kpartsholland.com/products/k75-k100-rebuild-driveshaft-20-tooth
