TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Lbxpdx on November 03, 2024, 06:28:03 PM
Title: Winter fuel question
Post by: Lbxpdx on November 03, 2024, 06:28:03 PM
On my old airheads I always filled up the tank with non ethanol during the winter, since they are steel.  With an aluminum tank, do you suggest empty or filled?  I have a spare parts bike that I was going to work on over the winter and was thinking since it is an aluminum tank that leaving it empty over the winter is fine.
What say ye?
Title: Re: Winter fuel question
Post by: natalena on November 04, 2024, 12:00:10 AM
Since the brick isn't ridden in winter much, it's always full non-ethanol 91, with a splash of Sta-bil. I usually run it to operating temps once or twice before getting out in spring. Cheers.
Ps, I like full tanks to keep everything submerged.
Post by: Chaos on November 04, 2024, 12:47:54 PM
Steel rusts, aluminum corrodes.  Very bottom corner of K bike tanks is were the water collects and tends to corrode out, common on bikes that sit for a long time.
Post by: Laitch on November 04, 2024, 01:08:14 PM
I've stored my Brick six months a year for the last 12 years and 70K miles with a full tank of fresh E10 conditioned with Stabil. People could eat off the floor of that fuel tank, it's so clean—one person at a time, of course. The engine starts right up in the spring and I ride off dedicated to use up that tankful as mindfully as possible.
:laughing4-giggles:
Post by: frankenduck on November 04, 2024, 02:12:56 PM
Rust is corrosion.
Post by: Laitch on November 04, 2024, 02:25:09 PM
Fish got to swim; birds got to fly.
Post by: Chaos on November 04, 2024, 02:26:51 PM
But is corrosion rust??
Post by: frankenduck on November 04, 2024, 02:40:58 PM
Rust is iron oxide corrosion. Aluminum alloys containing no Fe do not rust.
Post by: Laitch on November 04, 2024, 02:57:59 PM
Has Google broken? Will the mechanic's shade tree become the Bodhi of truth here?   :laughing4-giggles:
Post by: Kaos on November 04, 2024, 03:53:24 PM
And supposedly i am the one that brings Kaos.
Anywho. additive, full tank (low lead) and if you can, or just simply start it once in a while. Could easily do a month or so without starting.
Shake it, stir it, and or throw some screws in your tank (grandpa's tip) if you do see corrosion forming.
[fun fact] E10 could possibly start to deter after 2 within 3 months. Its not an overnight process.
BUT if its corrosion you're worried about, remove the tank drain it, dry it and use a tank liner.
or. just start it every now and then. ride it down the street when its an option. Then it shouldnt be a big issue. and cover your bike, it helps.
Post by: Chaos on November 04, 2024, 04:06:12 PM
Or buy a Ural and ride all winter
Post by: The Mighty Gryphon on November 05, 2024, 04:07:39 PM
ummm...
How did you get off the bike to take the picture without leaving any footprints in the snow???
Post by: Laitch on November 05, 2024, 06:37:44 PM
STA-BIL®-conditioned fuel won't separate for six months, at least, so the start of corrosion is defeated. Starting a Brick only now and then when it's idle just creates condensation in the crankcase, evocative odors, and pleasant memories but that's all it does. To place a battery that's in good condition into storage, take a farewell ride on the Brick then disconnect the ground strap from the transmission. I found covering the Brick when it's in storage invites mice habitation. I just plug the exhaust with a rubber stopper; mice can't enter the air snorkel because it's screened, so they move somewhere else. Sometimes the mice trek up the road to nest in our attic and have a once-in-a-lifetime feast on the homemade peanut butter I put in our mousetraps.
Otherwise, I'm 100% in agreement with Kaos.  4265249878
Post by: Bmwsquirl on November 06, 2024, 05:07:32 PM
Good afternoon
http://www.pure-gas.org (http://www.pure-gas.org)
Post by: rbm on November 09, 2024, 08:13:56 AM
I store my K-bike with the tank off, empty of fuel on a shelf.  I first run the engine with gas conditioned with Ethanol Shield to be sure that the petrol-delivery system on the bike is protected over the winter.  Ethanol Shield is a far superior product to Sta-bil. Sta-bil will not absorb water in the gas but Ethanol Shield will.
Post by: frankenduck on November 09, 2024, 11:56:19 AM
It also helps to have a dehumidifier in your garage. I do and it has made a world of difference.
Post by: K1300S on November 10, 2024, 12:29:55 PM
what Laitch said.  this is the right answer.  fill the tank to keep the moisture in the air from messing with metal parts, add stabil, run it for a few minutes to circulate the stabil infused gas through the system and leave it alone until spring.  take battery out or leave it on a good maintainer.  do not start it until spring, or whenever you ride it next.  I have left bikes for well over a year with this prep and they start right up, with no corrosion issues in the tanks.
Post by: Chaos on November 10, 2024, 02:40:41 PM
If you do start it up, take it out for a nice long run to get all the temps up. Around here there’s usually a day in January where it is 50 or 60 and it’s nice to blow all the cobwebs off.
Post by: The Mighty Gryphon on November 13, 2024, 01:58:58 PM
Dehumidifiers don't work for 5 months of the year around these parts.  Heck, the one in our basement ices up from November to March.  If I had one in the garage it would be frozen from mid-September to mid-May.
