TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => Project Classic Motobricks => Topic started by: rocketbrick on July 29, 2024, 05:11:47 PM
Hey y'all, been posting quite a bit here. A few things about lighting.
I'd like to get it a bit more up to modern standards in terms of illumination. I have an LED bulb I can plug into my current housing, but I've found they don't work as well as I hoped. With that in mind, I want to first install some AUX driving lights, and then update the main headlight.
Can you guys recommend some front-mounted driving lights and wiring diagrams for your mods?
What I plan to do as an FYI:
- I was thinking of mounting some amber Hella Halogen driving lights on the crash guards. I've also seen some ovular fork-mounted light installations that work well, but I'm not a fan of the ovular look, I like to stick with the square brick theme.
- I have an extra dash rocker switch from a donor bike, and I planned to wire that up to this aux lighting method.
- Once that's done, I wanted to update the square headlight to a dual-headlight setup (one hi beam, one low beam). It's ambitious, but it's what I want to do.
Below is a pic of an inspired bike I found on FB for the main headlight setup. The owner recommended using a pigtail to the second light, and modify the light housing mounting bracket (of which I have an extra). Is it really that easy?
EDITED for clarity.
Whatever happened to your project? It's been 180 days and counting.
Consider. 180 days elapsed without an answer to his query. Updates could have seemed pointless.
WORD. Leaving open-ended threads is really the issue isn't it? No need to answer, closed thread, it's a dud.
