TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Billk on May 25, 2024, 10:05:31 PM
Title: Fuel Mishap
Post by: Billk on May 25, 2024, 10:05:31 PM
I accidentally put diesel fuel in my 95 K75, complete fill up. It started by died immediately. Once I figured what I had done I emptied the tank of approximately 95% of the diesel and installed 2 gallons of 87 octane. After a difficult start it ran ok without any noticeable problem. Any recommendations or other problems I should be looking out for.
How did this happen? I selected 87 octane and used the wrong pump nozzle/fill.
Thanks,
Bill
Title: Re: Fuel Mishap
Post by: blackie1 on May 26, 2024, 01:02:27 AM
won't be a problem. maybe pull the spark plugs and give them a clean 112350
Post by: Laitch on May 26, 2024, 08:23:40 AM
As blackie has alluded, you've done a classic treacle-and-brimstone–style treatment usually given at orphanages and boarding schools described in Charles Dickens's work. Nowadays, we use Techron.  :laughing4-giggles: You've lubricated the hell out of the valves  icon_cheers ; use the Techron to clean the injectors and remove residue.
Post by: frankenduck on May 26, 2024, 11:42:15 AM
I'd replace the fuel filter too.
https://www.amazon.com/dp/B000C9WJBM/
Post by: Ingo on May 26, 2024, 08:31:20 PM
Don't overthink it. The diesel fuel left in the system is going to be diluted/flushed to nothing. The Techron is fine for helping to get the baked in oil off the valves/pistons/cyl-heads/spark plugs... so that seems advisable. Otherwise I'd say there is no lasting issue.
Post by: The Mighty Gryphon on May 27, 2024, 11:10:56 AM
A little bit of diesel won't hurt anything.  Back in the 60's we used to dump a quart of diesel or kerosene down the carburetor of a running engine to clean the carbon out of the cylinders.  The smoke was worse than starting up a Brick that had been sitting on it's side stand.
Post by: Laitch on May 27, 2024, 11:32:57 AM
That was part of the fun! Sometimes, it was even effective, but the therapeutic cloud was always impressive.
Post by: The Mighty Gryphon on May 28, 2024, 09:26:53 AM
Damn right!  That cloud was so satisfying.  It made you feel like you were really accomplishing something truly significant even if you were only making every flying insect in the neighborhood miserable for an hour or so.
Post by: Billk on June 07, 2024, 09:46:49 PM
I went through two tanks of gas without any problems. Next I will add the gas additive that was recommended.
Thank you all for your advise.
Bill
