TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: pinhead on May 03, 2024, 08:56:59 PM
Title: 1985 BMW K100RT won't idle
Post by: pinhead on May 03, 2024, 08:56:59 PM
My K100 won't idle when its warmed up.  I have turned idle adjustment all the way up and doesn't help.  Any suggestions what the problem could be?
Title: Re: 1985 BMW K100RT won't idle
Post by: The Mighty Gryphon on May 03, 2024, 09:33:48 PM
First thing I would look for is an air leak.  The crankcase breather tube(AKA "Z" tube) or the bushings above and below the throttle bodies are usual culprits.
Another possibility is a faulty coolant temperature sensor.
There is information on how to check these items here at the forum.
Post by: pinhead on May 04, 2024, 01:30:30 AM
I changed the coolant temperature sensor a few weeks ago and no improvement.  I replaced that z tube last fall.  but no change .....
Post by: frankenduck on May 04, 2024, 04:39:52 AM
My first guess is throttle body boot(s).
https://www.kbikeparts.com/classickbikes.com/ckb.tech/0.ckb.tech.files/tbleak/tbleak.htm
Part 11611460408
They "only" cost $61 each these days and you want to replace all of them so you're looking at $244.
Would I pay that much? Not in a million years - because a I have both Swedish and Scottish genes trying to out-cheap each other.
The last K75 that I bought had a bad TB boot. I paid less than $30 shipped for a used set of three on Ebay - knowing that I could return them for free if I didn't like them. Turned out that they were in great shape so I gave them a 303 bath and installed them.
https://www.kbikeparts.com/classickbikes.com/ckb.tech/0.ckb.tech.files/k75pa.rehab/k75parehab.htm#fuel.rail
Post by: Bmwsquirl on May 04, 2024, 07:28:15 AM
For boots try a company called siliconeintakes.com
Squirrel
Post by: pinhead on May 04, 2024, 10:47:39 PM
thanks all!  I am going to do that propane test for leaks and see what happens.
