TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: grosbeak on March 24, 2024, 05:01:48 PM
Title: Gen 1 tragkorb Repairs
Post by: grosbeak on March 24, 2024, 05:01:48 PM
The Gen 1 cases on my 1992 K75S were in rough shape when I got the bike. Problem areas included:
- Cracks in the cases (both large and small)
- Seal channels on the inner cases (mangled or separated)
- Seals (dried up or missing)
- Both lid restraints
- Latches (top and side)
Because fixing broken stuff is my jam, I decided to give it a try. I’ve learned Gen 2 cases are better than Gen1, and Gen 3 cases are better yet. If the repairs fail, replacements can be found.
Title: Re: Gen 1 tragkorb Repairs
Post by: jiggseob on July 22, 2024, 12:28:10 AM
Did you ever make any progress on those hardcase repairs?
Mine need a couple hinges, which are available, scared to see how mucho CAD pesos that will be at Psycho-Jerks in Edmonton.
I also need a latch, the one that holds the case to the frame, not one of the two that hold the case shut...  Any ideas on source?
My 92 K75 RT came to me missing one side-panel (side cover?)  I made a replacement out of sheet metal.
Post by: grosbeak on January 24, 2025, 10:51:05 AM
Sorry for the late reply! Yes, I got them all fixed up. Here's a video!
https://youtu.be/U5vV2moukZE?si=c1Mw_PMTEAsd5w92
Post by: Edward on January 24, 2025, 01:15:16 PM
Excellent video!
Post by: jiggseob on January 24, 2025, 01:56:40 PM
Excellent video.  I've done the latches of one of my saddlebags that way, and some have commented that "hardware store" latches look like "hardware store" and not up to the fine fit and finish of a BMW.
I say these adjustable latches are far far far superior to the stock BMW latches in terms of function as a latch.  I got mine at a boat-stuff store, in stainless steel, probably cost more for one latch than Grosbeak paid for four.  The downside of stainless steel latches is that the paint I spray on them just flakes off.  The plated steel ones would probably hold paint a little better.
Well Done and Thank You Grosbeak.
Post by: frankenduck on January 24, 2025, 02:34:59 PM
I replace the plastic hinges with aluminum piano hinge:
https://www.kbikeparts.com/classickbikes.com/ckb.tech/0.ckb.tech.files/pianohinge/pianohinge.htm
