TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Batan on January 13, 2024, 12:31:31 AM
Title: Period correct driving lights?
Post by: Batan on January 13, 2024, 12:31:31 AM
Quite new on the forum, I got my first K-bike today. An '87 K75S.
I will be insuring it as a collector here in BC, Canada and as such it needs to have period correct modifications - if there are any. I am thinking about adding driving lights and was wondering if anybody knew of any period correct or even factory options for the year.
(Ideally I'd use the period correct lights but with LED bulbs inside.)
Thanks!
Title: Re: Period correct driving lights?
Post by: frankenduck on January 13, 2024, 11:02:46 AM
PIAA 1100X were popular on Ks back in the day and now come in LED. However, the original ones had a silver casing and the LED 1100P are black.
Post by: Batan on January 13, 2024, 09:53:18 PM
I will check them out, thank you.
Post by: lefthander on January 16, 2024, 07:07:27 PM
 I have a set that I believe are OEM from the early k bike era. They are rectangle, black and when you push the switch one light comes on as a single driving light. When you switch to hi-beam that light turns off and the other light comes on. I believe it is supposed to operate as a fog light. I'm sure others here know more detail regarding these lights. This is just what I've had.
Post by: Batan on January 16, 2024, 07:12:56 PM
Do you have a photo?
Post by: Chaos on January 16, 2024, 07:16:21 PM
I have a set that I believe are OEM from the early k bike era. They are rectangle, black and when you push the switch one light comes on as a single driving light. When you switch to hi-beam that light turns off and the other light comes on....
Friend of mine had an 86 K75T with those, I think they were OE  (the T was USA only) He could switch back and forth between hi and low beams and the lights would alternate, cars ahead of him thought he was the law and pulled over :laughing1:
Post by: Batan on January 16, 2024, 07:29:49 PM
Those are... huge!
