TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: DuncK1100 on November 24, 2023, 06:47:48 AM
Title: 4 Valve A or B
Post by: DuncK1100 on November 24, 2023, 06:47:48 AM
Hi,
Can anyone explain the terms 4V A and 4V B to me.
I have a '94 K1100LT.
Thanks in advance.
Title: Re: 4 Valve A or B
Post by: Laitch on November 24, 2023, 07:39:15 AM
Welcome to the forum, Dunc!
In what context did you find those terms?
Post by: Duckbubbles on November 24, 2023, 11:19:30 AM
Haven't heard those terms, but could it refer to the 1000cc (4 valve A) and 1100cc (4 valve B)?
Frank
Post by: jbt on November 24, 2023, 11:20:39 AM
Maybe it's because there was a slight modification of the connecting rods lenght  in august 1992, passing from 125 to 131mm.
So the pistons are different also, the stroke did not change.
Post by: Laitch on November 24, 2023, 03:20:06 PM
The lists below are from MaxBMW's K1100LT parts list.
Post by: Duckbubbles on November 24, 2023, 10:03:07 PM
If I remember correctly, those ratings are used at the factory to match sizing and weight of reciprocating parts.  Ran into this rebuilding a K100 engine probably 30 years ago.  I think a similar system is used for piston rings and bearings, and probably more.
Frank
Post by: jbt on November 25, 2023, 12:59:22 AM
For Airheads, A, B and C were markings used to match pistons precise size to the different bore sizes of the cylinder, according to the manufacturing variations within 3 classes of tolerance.
K1100 pistons have the same kind of classification, with 2 classes only. They are rated A and B.
