TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => Project Custom Motobricks => Topic started by: ming on September 09, 2023, 07:36:34 AM
Title: 3 spoke wheel
Post by: ming on September 09, 2023, 07:36:34 AM
hi all
i saw this bike advertised on fleabay, its an k1100 with the non floating discs, 4 stud fixing same as the k100, what wheel is this off as every other k1ioo wheel i've looked at is mounted differently?
many thanks
ming
Title: Re: 3 spoke wheel
Post by: Laitch on September 09, 2023, 12:34:08 PM
That looks like a K100, ming. It has a 2-valve K100 camshaft cover, 2-valve air intake system, and two-pot instead of 4-pot brake calipers.
Post by: Laitch on September 09, 2023, 01:10:36 PM
Incidentally, the front discs on that Brick are floating discs which, as is obvious, can be had for K100 and K75 models. The fork looks K100. The wheels are likely stock 2-V mounted with the widest tires that will fit between the fork legs without rubbing them.
Post by: ming on September 09, 2023, 02:18:43 PM
hi laitch
so that front wheel is from a k100? thought only the later k1100 and the rt models had 3 spoke? as i said earlier the discs are definately k100 but i can't reference a three spoke with those discs?
cheers
 ming
Post by: Laitch on September 09, 2023, 03:14:10 PM
I've discovered in my life that thinking isn't everything it's cracked up to be, ming.  :laughing4-giggles: Attached is an image from MaxBMW's parts fiche showing a three-spoker front wheel available for the 2-valve K100 models in the later years of their production. The late K75 models could get them, too. Mine has them.
Post by: ming on September 09, 2023, 03:16:46 PM
cool, thats some good info there m8 !! will do a search for those
cheers
ming
Post by: frankenduck on September 09, 2023, 06:15:04 PM
The rotors are EBC:
(https://s.turbifycdn.com/aah/yhst-15102260216258/ebc-k75-100-2v-front-brake-rotors-non-abs-pair-md604ls-rs-17.jpg)
left   MD 604 LS
right   MD 604 RS
